Rear shocks lh torana
#1 _chookies6_
Posted 21 July 2017 - 07:59 PM
Sent from my SM-G920I using Tapatalk
#2 _Lazarus_
Posted 21 July 2017 - 08:15 PM
It's a bit like having sex for the first time.
You might need a manual.
Posted 21 July 2017 - 08:49 PM
It is super easy. The nut that screws on to the top of the shock is accessed through the boot compartment. There may or may not be a rubber plug in the top of the shock tower on top of the rear wheel arch. Remove this and use a socket to remove the nut, washer, and rubber grommet. Then crawl underneath and undo the bolt that goes through the bottom of the shock and pull it out. Having jack stands under the chassis rails will give you more room to move, and give the shock room to compress.
Posted 22 July 2017 - 09:55 PM
Plenty of "educational" videos online these days
Posted 25 September 2017 - 11:06 AM
Was there any dealer options, where they fitted air shockys to the rear?
Posted 25 September 2017 - 11:34 AM
Posted 25 September 2017 - 08:00 PM
Yes, they were optioned using the name Superlift shock absorbers.
Thanks for that
