Anti pollution
5 replies to this topic
#1 _Brenton_
_Brenton_
Posted 06 August 2017 - 03:44 PM
Hi guys trying to work out if my pollution gear is hooked up correctly I'm running a 600 Holley
#2 _Bomber Watson_
Posted 06 August 2017 - 05:03 PM
Gday mate supplying a photo or simmilar of your current setup as well as what year model your car is and what ADR it has to comply with may help a bit.
Most 4165 series Holleys (Ie most 600cfm) you cant connect the pollution gear up properly as they do not have an external fuel bowl vent, but will work for anything pre june 74 tmk.
#3 Bigfella237
  • 4,371 posts
Posted 06 August 2017 - 07:04 PM
First post Brenton, welcome to the forum.
If you're running a 600 Holley then I highly doubt all your pollution control gear is hooked up, but there are varying degrees of "hooked up" too!
#4 _Brenton_
_Brenton_
Posted 06 August 2017 - 07:11 PM
Sorry guys it's 77 lx 308 manual it's got the 1850-3 4160 vac secondary I'm in sa and need to do vehicle Id to transfer rego to sa had the car a few years now thought i should try rego it before I rebuild it
Thanks only new to this
#5 Ice
  • 15,122 posts
Posted 06 August 2017 - 07:25 PM
Yes as Bomber said pics would help but there is ways around the pollution gear
As Andrew said there is hooked up some how
#6 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 07 August 2017 - 10:25 AM
Welcome Brenton. This might give you a clue.
Attached File  FullSizeRender 5.jpg   35.72K   5 downloads
