XU1 Radiator
23 replies to this topic
#1 _John D_
_John D_
Posted 07 August 2017 - 05:55 PM
After some help re Correct Radiator for an Early 72 XU1. Adelaide Build.
Think these were a Heavy Duty radiator with extra fins.
I understand they have there own part numbers but is this on the radiator somewhere and if so where are they.
Also supposed to be a date code but where is that stamped.
What else is different and what is the correct Fan shroud. Have seen various types.
Some pics would be great.
Thanks in advance.
#2 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 07 August 2017 - 09:55 PM
John ,First photo is for a 1,2 and 3rd month 72 xu1 date is M1 .The second photo is for a 5th and 6th month 72 xu1 date is D2 which are both early 72 xu1's .
#3 Davis
Davis
  • 343 posts
  • Name:Drew
  • Car:LC 2 door
Posted 07 August 2017 - 11:23 PM
Out of curiosity what actually distinguishes an xu1 radiator from a standard one. I just had a look at a torana radiator ive got which is stamped H2, what does this actually refer to? Thanks
#4 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 07 August 2017 - 11:32 PM
Hi Andrew, 8th month 1972 = h2 Gary.
#5 crabba67
crabba67
  • 903 posts
  • Name:anthony
Andrew,I've only seen M1,D2,G2,H2 and K2 for 1972 lj torana heavy duty radiators
Edited by crabba67, 07 August 2017 - 11:36 PM.
#6 Davis
Davis
  • 343 posts
  • Name:Drew
  • Car:LC 2 door
Posted 07 August 2017 - 11:44 PM
Thanks lads...
#7 _John D_
_John D_
Posted 08 August 2017 - 12:52 PM
Thanks for the info guys,
The radiator has a J2 mark, Which is Sept 1972.
The car was Built in Feb 72. Interestingly the car also has a June 72 dated Head.
As per other comments what else distinguishes a XU1 or Heavy Duty radiator.
Is there a part no. on them somewhere??
#8 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 08 August 2017 - 08:13 PM
No mate, no part number on them. Different in looks & a assembly code sticker when new, so there wasn't really a need for the part number. 14 fins per inch. As for the shroud or fan gaurd, Anthony has posted the top of 2 xu1 radiators have a look at them and others & you should work it out.
#9 Davis
Davis
  • 343 posts
  • Name:Drew
  • Car:LC 2 door
Posted 08 August 2017 - 09:09 PM
Found this older thread on xu1 radiators, starts about halfway down page 1. Some good reference pics
http://www.gmh-toran...er-cap-lj-xu-1/
#10 _John D_
_John D_
Posted 08 August 2017 - 10:27 PM
Thanks Guys, I think that clarifies for me.
Good info.
#11 _duggan208_
_duggan208_
Posted 09 August 2017 - 12:11 AM
So the difference between the standard radiator and the XU1 is that the XU1 has 14 fins per inch, so the standard radiator must have less fins. Did the XU1 radiator have a 3 or a 2 row core?
regards
#12 S pack
  • 15,538 posts
Posted 09 August 2017 - 06:33 AM
regards
Just more fins per inch over std that is all.
Edited by S pack, 09 August 2017 - 06:34 AM.
#13 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 09 August 2017 - 12:04 PM
That's not all actually. The XU-1 radiator has 3/8" between the vertical tubes and the standard ones have 1/2" between the tubes. Over the width of the radiator, this equates to approx 30-40 more vertical tubes. The XU-1 radiator also has 5/8" tube cores and the standard has 1/2" tube cores. The 14FPI is the least effective difference between the cores.
#14 _flyxu1_
_flyxu1_
Posted 09 August 2017 - 09:42 PM
Hi there
gone through my collection
and there more date codes for the top tanks
 Photo attached
F2 heavy duty xu1 rad
E2 heavy duty xu1 rad
and a nos one i bought some time ago C2
cheers Grantley
#15 71xu1
71xu1
    Dave
  • 1,265 posts
  • Car:LC GTR XU1
Posted 09 August 2017 - 11:58 PM
Another difference is overflow hose held on with clips on side not metal prongs bent out from pressing of radiator straps.
#16 RM125n
RM125n
  • 54 posts
  • Car:TORANA
Posted 21 August 2017 - 02:18 PM
Hi there
 Photo attached
cheers Grantley
Thanks for posting photos of your heavy duty , xu1 top radiator dated tanks.
Is there any chance that you could post a couple of photos of how the overflow pipe runs on your original Holden xu1 radiators ?
#17 _flyxu1_
_flyxu1_
Posted 27 August 2017 - 07:12 PM
Hi there
sorry for the late reply
is this what you are looking for ?
cheers Grantley
#18 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 27 August 2017 - 09:02 PM
Early LJ XU1
#19 RM125n
RM125n
  • 54 posts
  • Car:TORANA
Posted 29 August 2017 - 04:36 PM
Hi there
cheers Grantley
Early LJ XU1
I would to thank you both on posting the photo's of the heavy duty , xu1 over flow pipe on how it runs
Anthony I got a question is there any difference between early LJ XU1's to Late LJ XU1's on how the over flow pipe runs on the radiator ?
#20 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 29 August 2017 - 05:41 PM
This is a late HQ or early HJ  still with the overflow hose attached to the back of the radiator not down the side.
#21 S pack
  • 15,538 posts
Posted 29 August 2017 - 06:08 PM
^^^ HJ Holden
#22 RM125n
RM125n
  • 54 posts
  • Car:TORANA
Posted 31 August 2017 - 08:50 AM
Anthony thanks for the information I can see what you mean in this photo.
Holden was still running the over flow on back of radiator as late as the HJ model
#23 ZUSE
ZUSE
  • 91 posts
  • Name:ZUSE
  • Car:GTR TORANA
Posted 31 August 2017 - 05:17 PM
xu1 radiator
part no by natra holden xu1  825 14 f.p.i 38mm core
stadard holden torana  926 12 f.p.i 32mm core
tank date codes have no reference  on core date only
at the time natra supplied radiators
#24 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 24 April 2020 - 11:41 AM
Mark MFM look at post #18 a pic of early LJ xu1 with CLIPS,keep reading old posts and learning.
