Approximate weight of LX Hatchback door glass and all door internals?
11 replies to this topic
#1 adrianh08
adrianh08
  • 219 posts
  • Name:Adrian Haynes
  • Car:1974 LH
Posted 17 August 2017 - 11:48 AM
I am setting up my doors and gettting gaps right etc on my Hatch and want to try and cheat a little to save myself re installing and then completely removing again all the door internals including glass.
Setting the gaps etc without the weight of all the internals will lead to issues. (Door sags with extra weight)
Anyone know or done it before where they get an approximate weight of glass, latches and all internals and just put weights inside door to replicate?
I'm guessing between 7-10kgs but that's all it would be, a guess.
If someone has done this and knows it would save me a bunch of time.
Thanks in advance.
#2 _LS1 Taxi_
_LS1 Taxi_
Posted 17 August 2017 - 02:48 PM
It won't sag when closed as the gaps are set by the location of the striker. No need to worry about the weight.
#3 Bigfella237
  • 4,362 posts
Posted 17 August 2017 - 07:54 PM
Eww, I hope that comment was tongue-in-cheek, Daz?
The latch/striker should have absolutely no vertical weight on it whatsoever, in fact I would recommend not even fitting the strikers until the doors are properly aligned, same goes for bonnets, boots, hatches or any other kind of opening panels.
The only weight on the strikers should be lateral (across the car) against the compression of the rubbers/seals/stoppers. Otherwise you'll have a very clunkily closing panel.
#4 _LS1 Taxi_
_LS1 Taxi_
Posted 18 August 2017 - 08:12 AM
It wasn't tongue in cheek 😬
I'm definitely less fussy than most. Brains wired too practical for that...the end result is more important than the journey travelled to my type I suppose. Being a mechanic it's probably how it needs to be otherwise I'd never finish a job. Dunno, hadn't given it much thought before!
#5 308 Sunbird
308 Sunbird
  • 963 posts
  • Name:Stuart
Posted 18 August 2017 - 01:51 PM
Time to break out the bathroom scales and calculator Adrian
#6 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 18 August 2017 - 04:34 PM
I have some very accurate scales and spare bits I can weigh on the weekend.
#7 adrianh08
adrianh08
  • 219 posts
  • Car:1974 LH
Posted 28 August 2017 - 12:54 PM
All good guys i have all the bits and can weight them up myself just thought it was the kind of thing someone else may have already done. Thanks anyway.
#8 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 28 August 2017 - 05:51 PM
yeah sorry mate life got in the way.  I got the glass and reg out and didn't get any further.  let me know if you need me to keep going.  Can do it tonight.
#9 Bigfella237
  • 4,362 posts
Posted 28 August 2017 - 09:26 PM
I'm sure I've got a pair of complete doors (incl. glass, internals etc.) somewhere too, but I neither have an accurate set of scales nor a spare month to dig them out. :blink:
I always planned on buying a set of corner weight scales and weighing everything as I went along but somehow never got a round tuit.
I actually thought Heath would've been all over this subject?
#10 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 29 August 2017 - 03:26 PM
Some beers and a few mates to help align
would b easier.saves mucking about..
#11 Peter UC
Peter UC
  • 763 posts
Posted 01 September 2017 - 12:38 PM
You could just put all the glass and mechanism in the door without installing them, that couldn't take longer than a couple of minutes, just a thought.
#12 Cook
Cook
  • 1,497 posts
Posted 01 September 2017 - 06:11 PM
Peter UC, logical thinking.  My guess is that he hasn't got all the components yet otherwise he could weigh them.  Cheers ron
