Which diff is this?
9 replies to this topic
#1 77lx308
77lx308
  • 280 posts
  • Name:Mike
  • Car:77 lx 308
Posted 19 August 2017 - 08:54 PM
Hi folks
Simple question for the gurus.
Is this a salisbury?
Came off a wrecked UC so assume it is.
#2 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 19 August 2017 - 09:36 PM
8 Bolt Salisbury from UC methinks.
#3 Bigfella237
  • 4,371 posts
Posted 19 August 2017 - 11:46 PM
Upside down Miss Jane
#4 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 20 August 2017 - 10:31 AM
Why is it called an eight bolt when I can see ten?
#5 dattoman
  • 16,470 posts
Posted 20 August 2017 - 11:43 AM
Cause that's just the inspection cover.... open it up
#6 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 20 August 2017 - 12:57 PM
Is it eight bolts for the ring gear? And if so, does the ten bolt in the early Monaros have ten? Is there a twelve bolt? Does this only apply to Salisburys or are Borg Warners known by the same system? (Never even thought about this before)
#7 76lxhatch
  • 7,152 posts
Posted 20 August 2017 - 01:29 PM
Don't know why those terms are used for the Holden diffs these days, they always used to be just big and small Salisbury. Counting the crownwheel bolts applies to the Chev(/BOP) diffs, 10 bolt, 12 bolt. A 10 bolt Chev diff is nothing like a large Salisbury.
#8 77lx308
77lx308
  • 280 posts
  • Name:Mike
  • Car:77 lx 308
Posted 20 August 2017 - 01:52 PM
Thanks folks..
#9 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 20 August 2017 - 06:45 PM
It's a Salisbury design, with internals the strength of a banjo, be fine behind a std 253. & that's about it.
#10 myss427
myss427
  • 1,636 posts
Posted 21 August 2017 - 11:04 AM
Yes, 12 bolt was also the amount of bolts on the ring gear, 10 bolt ect. But Australian 10 bolts had a 7.56 inch ring gear where Yank 10 bolts had a 8 inch ring gear, but horrible C clip axels.
