LX tag verification please.
5 replies to this topic
#1 tinkers
tinkers
    Admin
  • 3,796 posts
  • Name:Kerri
Posted 23 August 2017 - 09:27 PM
Can someone decipher the following
Chassis CLX037326M
Vin #      8D69TG J550968X
Eng #     ZT22755 <- that isnt original is it?
MODEL CODE     LX8VD69
BODY #                 550968M
Trim                       1890-18V
PAINT                   568-15953
ENG       L31         TRANS M21        RR AXLE GU7
 Thanks in advance.
Sent from my phone using Tapatalk
#2 dattoman
  • 16,461 posts
Posted 24 August 2017 - 12:17 AM
https://australianmu...000-torana.html
Attached File  mandy.jpg   124.21K   9 downloads
#3 tinkers
tinkers
    Admin
  • 3,796 posts
  • Name:Kerri
Posted 24 August 2017 - 12:21 AM
Thanks. The car is currently in WA
Sent from my SM-A520F using Tapatalk
#4 Bigfella237
  • 4,362 posts
Posted 24 August 2017 - 03:57 AM
Going by the details provided it presents as an 03/77 LX SL/R5000, 4 speed manual, with a 2.78:1 diff, in Mandarin Red with Slate Black trim.
The thing is, the VIN/Body number is around 4 months too early for that chassis number, I would expect to see that body number on an 11/76 car, some cars got held-up on the assembly line (so the story goes) but 4 months is a big delay?
Plus Mandarin Red (1890 / 568-15953) is a 1976 colour, it was replaced by Madeira Red (1928 / 568-30519) in 1977/78.
Also it has the early straight-shaft V8 brake booster, which changed to the bent-shaft type boosters in Dec'76, after 40 years it may well have been changed but that's just another nail in the coffin?
And it's pretty obvious that the tags have been R&R'd at some stage (can't see the VIN tag close enough to tell), but again, a lot can happen over 40 years. There are a number of other things you could check on the car in person, but I would certainly be suspicious if looking at buying this car myself.
The "ZT22755" engine number is a 308 from a 1979 HZ Holden (but not a Statesman). Do you happen to have the cast date off the front of the engine?
Edited by Bigfella237, 24 August 2017 - 03:57 AM.
#5 _sbc57lx_
_sbc57lx_
Posted 24 August 2017 - 02:39 PM
And there's a spanner fitted on the inside of the nose cone, just above the battery . I don't thing the factory ever fitted those.
 My 6/76 SS had the bent type brake booster shaft
#6 tinkers
tinkers
    Admin
  • 3,796 posts
  • Name:Kerri
Posted 24 August 2017 - 02:48 PM
LOL I didnt notice the spanner.
Thanks for the replies.
