what ring gaps are everyone running with there turbo holden 6,combo will run 26psi,acl duralite pistons,moly rings.
ring gaps turbo holden 6
Posted 29 August 2017 - 11:14 AM
Posted 30 August 2017 - 08:38 PM
Sorry for the derail- but 26PSI and duralite pistons? Since you are asking about ring gap, I presume you havent built the motor yet? If so, I would seriously consider forged pistons with that kind of boost.
Sure you can run cast slugs and it will probably hold up, but at the end of the day you are only a few bad batches of fuel away from damage with that kind of boost.
In saying that, if you run good fuel like E85 and are conservative with timing, you should be sweet...
#3 _Bomber Watson_
Posted 30 August 2017 - 09:17 PM
Yeah I opened this thread, read that, and decided to close it again....
Posted 30 August 2017 - 11:21 PM
but still comented
Posted 31 August 2017 - 12:25 PM
running 26psi with duralite pistons has been done before by others
Posted 31 August 2017 - 12:37 PM
I'm a mega tightarse and I still ceramic coated my Hypereutectics slugs even to run only 10psi.
Posted 31 August 2017 - 06:01 PM
I know people that have drunk their own piss, doesnt make it a good idea though.
If you run good fuel (E85) you will probably be ok BUT I would still be hesitant leaning on it.
Posted 31 August 2017 - 07:29 PM
#9 _Bomber Watson_
Posted 31 August 2017 - 10:33 PM
Yeah at the end of the day if you want real world advice why dont you ask the "others" who have "run 26psi on duralites" what ring gap they ran?
If you want speculation, bullshit and people trying to get you to spend the $7 extra it is to get forgies over duralites then ask in the forum that has the highest saturation of guys who have done silly things with Holden sixes then argue with everything said hahaha.
I'd go about .020" or so btw.
Posted 31 August 2017 - 10:35 PM
the main thing is no detonation you should be alright with cast pistons, i would be buying a set of h beam rods, conrods and rod bearings will take most of the punishment.just for piece of mind run forged piston=insurance.
Posted 01 September 2017 - 06:28 AM
Try this
http://www.spoolimpo...-forged-pistons
