GTR Instrument Cluster
24 replies to this topic
#1 Crackers222
Crackers222
  • 21 posts
  • Name:Pedro
  • Car:'71 LC 4door S
Posted 31 August 2017 - 03:32 PM
 Hi all,
I have recently purchased this GTR dash. Hopefully the attachments turn out.
It is stamped on the back in a triangle with 9 at top, then 7 - 73 at the bottom. I assume it is from a "73 beast. Is it possible that it was from an XU-1 or just generic '73 I note what appears to be an extra lamp at top centre for something. can anyone tell me what this is please? I think I read somewher that this modification was only for '73 models.
I also note the fuel guage is not original. Did the GTR dashes come out with different guage locations? I had an LJ GTR back in "85 and I am sure that this instrument config is the same as mine was but I have seen other dashes with different configs.
Any tips or links to threads for installing into a '71 S 4dr would be appreciated
Thanks in advance
PedroAttached File  received_1923310551259098_resized.jpeg   245.06K   14 downloadsAttached File  received_1923310554592431_resized.jpeg   268.02K   8 downloads
#2 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,080 posts
  • Car:ɐuɐɹoʇ
Posted 31 August 2017 - 03:50 PM
Hi
It is from the last half of 1973 (metric instruments) - it was the gauge cluster that was standard on GTRs XU-1s and optional on other models. The light at centre top is the brake fail/handbrake light that was relocated from the centre bottom from 1/1/73. The fuel gauge is not original.
To install it easily, you would need the correct wiring loom - but I am sure that some folks have a workaround for that.
Bazza
#3 Crackers222
Crackers222
  • 21 posts
  • Name:Pedro
Posted 31 August 2017 - 06:22 PM
Thanks Bazza.
Time to get the glasses out and start looking at some wiring diagrams 😊
#4 hutch
hutch
  • 1,419 posts
  • Name:Phillip Hutchinson
  • Car:1972 LJ,2 door SL,wants to be an XU1
Posted 31 August 2017 - 06:55 PM
You can modify a standard loom with out to much trouble,all that's needed is the ammeter feed and a tachometer wire
#5 Crackers222
Crackers222
  • 21 posts
  • Name:Pedro
Posted 31 August 2017 - 07:41 PM
Thanks Hutch.
I think I might need extra bulb holders for the instruments. I will do some more research.
Edited by Crackers222, 31 August 2017 - 07:44 PM.
#6 S pack
  • 11,283 posts
Posted 31 August 2017 - 08:08 PM
Thanks Hutch.
The globe holders for the 2" gauges are different from the std instrument globe holders and the globe holder for the GEN light is different again.
#7 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,337 posts
  • Name:MAZ
  • Car:72 LJ SL SEDAN. 69 LC S 2 DR SEDAN
Posted 31 August 2017 - 09:58 PM
Aaron sumners has those globe holders also
he has converted my std lc wiring to suit
gtr dash instrumentation.
Attached File  1504178888030-404703906.jpg   501.88K   13 downloads
#8 Crackers222
Crackers222
  • 21 posts
  • Name:Pedro
Posted 01 September 2017 - 11:16 AM
Thanks for the info. I'll sus this out
#9 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,337 posts
  • Name:MAZ
Posted 01 September 2017 - 12:49 PM
Pic of the 4 push in holders just to show you.
Attached File  IMG_5978.jpeg   91.91K   14 downloads
#10 fx48_eh64
fx48_eh64
  • 163 posts
  • Name:MrFX
  • Car:Fx
Posted 01 September 2017 - 01:14 PM
curiosity makes me ask, how much is a XU! dash worth?  i saw one at a swap for 1000 bucks the other day, the same price he was asking for a set of triple cd175 strommys on a holden manifold
#11 Crackers222
Crackers222
  • 21 posts
  • Name:Pedro
Posted 01 September 2017 - 01:35 PM
I've only searched recently and I have seen varied prices ranging from $250 -$1000, depending on condition, original instruments and if it comes with a loom. I talked got mine $325 but fuel guage is not original and no loom.
Thanks again MAZ,
This will help with sourcing what I need,
Pedro.
#12 Crackers222
Crackers222
  • 21 posts
  • Name:Pedro
Posted 12 October 2017 - 07:14 PM
So can anyone tell me if the odometer is in miles or kilometres for this cluster?
Edited by Crackers222, 12 October 2017 - 07:23 PM.
#13 grumpy xu1
grumpy xu1
  • 1,460 posts
  • Name:Gary
  • Car:lj xu1
Posted 12 October 2017 - 07:40 PM
Klms on the outside, MPh on the inside "dual scale" 200 = "roughly" 120
#14 S pack
  • 11,283 posts
Posted 12 October 2017 - 07:58 PM
The odometer in OEM dual scale speedometers records the distance travelled in kilometers.
Edited by S pack, 12 October 2017 - 07:59 PM.
#15 grumpy xu1
grumpy xu1
  • 1,460 posts
  • Name:Gary
  • Car:lj xu1
Posted 12 October 2017 - 08:22 PM
I should have actually read the question, or borrowed Dave's glasses, sorry mate, i thought it said speedometer. Thanks for the fix up Dave. Gary
#16 jpxu1
jpxu1
  • 258 posts
Posted 12 October 2017 - 09:42 PM
Your instrument cluster is from a GTR/XU1 as it is fitted with a 120mph speedo. Gauge instrumentation fitted to S/SL models had 100mph speedos.
Secondly, the ammeter/oil pressure gauges have been reversed at some stage.
Thirdly, the temperature/fuel guages have also been reversed from how they were originally assembled, but that is only for LJ models.They are currently in the correct position for LC configuration.
Cheers,
JPXU1 :spoton:
#17 Crackers222
Crackers222
  • 21 posts
  • Name:Pedro
Posted 13 October 2017 - 10:00 AM
haha Gary. I have the same issue. Can't see with them, can't see without them. Thanks
Thanks Dave  :D
#18 Crackers222
Crackers222
  • 21 posts
  • Name:Pedro
Posted 13 October 2017 - 10:05 AM
Cheers,
JPXU1 :spoton:
Hey, thanks.
This is useful information. I wasn't aware that the cluster was from a GTR XU-1 so maybe it's a good score.  The fuel gauge is not original but i was suspecting gauges may not be in correct spots. I had a '72 LJ GTR in the 80'sand I know they were in different locations in it compared to this cluster. Appreciated.  Pedro  :D
Edit, my bad you say GTR or XU-1. Got it, Thanks again.
Edited by Crackers222, 13 October 2017 - 10:10 AM.
#19 grumpy xu1
grumpy xu1
  • 1,460 posts
  • Name:Gary
  • Car:lj xu1
Posted 13 October 2017 - 11:07 AM
Worst thing is Pedro, i don't actually need or have glasses, i just read it fast and didn't pay enough attention otherwise id have an excuse, Gary.
#20 jd lj
jd lj
  • 1,328 posts
  • Name:James D
  • Car:LJ SVO
Posted 13 October 2017 - 05:26 PM
Cheers,
JPXU1 :spoton:
I'm sorry but this myth about the 120mph/200kph speedometer is about to be busted.
My two door S model has the above mentioned speedometer fitted from the factory along with all its other optional upgrades. Maybe this became std in all the sports instrument clusters in the second half of 73??
#21 S pack
  • 11,283 posts
Posted 13 October 2017 - 05:34 PM
Back in 1980 I looked at a Chateau Mauve 5/72 LJ 82311 that was for sale. Optioned with 173 M20 disc brakes and sports instrument cluster which had the 120mph speedo.
Man it had more rust than the Cherry Venture :)
Edited by S pack, 13 October 2017 - 05:36 PM.
#22 grumpy xu1
grumpy xu1
  • 1,460 posts
  • Name:Gary
  • Car:lj xu1
Posted 13 October 2017 - 06:55 PM
I can remember a 73 4 cylinder 4 speed lj when i was younger, 1 owner had a factory sports dash & console & it wasn't the only 1, seemed more common in the 73 models. It was optional like other things . Gary
#23 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,080 posts
  • Car:ɐuɐɹoʇ
Posted 13 October 2017 - 07:18 PM
Hi
The parts catalogue also supports the view that all speedos fitted to gauge clusters were 120 mph/200kph.
This pic is from late '73 owners manual (note that the fascia is not a '73).
Bazza
#24 grumpy xu1
grumpy xu1
  • 1,460 posts
  • Name:Gary
  • Car:lj xu1
Posted 13 October 2017 - 07:50 PM
Top work Bazza, Gary.
#25 VDO
VDO
  • 92 posts
  • Name:Chris Curtis
Posted 14 October 2017 - 08:07 AM
A shame that many people swapped out the original fuel gauge, when all it needed was a new resistor.
