Supra bell housing modification
5 replies to this topic
#1 _Tassie LJ_
_Tassie LJ_
Posted 03 September 2017 - 10:31 AM
Hi, I was reading the posts regarding installing a supra gearbox in a LX and have also been talking with Toranamuk. One thing still couldn't find on the posts was what modification you need to do to the clutch fork opening, I believe it needs squaring up. I will be going full cable using a UC cable and the mod to the UC pedal. I have a CRS bell housing. If there is an existing post regarding this can someone put up a link please. When going back over the posts from you guys some photos will no longer show, is it possible for one of the Admin to repost the photos or make this a stickey as I am sure people are still needing this info. Cheers
#2 rexy
rexy
  • 3,584 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 03 September 2017 - 04:55 PM
You need to mock it up.
Fit clutch to engine.
Fit bellhousing , fork and throw out bearing.
Adjust pivot ball height so fork is as per image.
Attached File  IMG_8688.JPG   18.67K   8 downloads
You should have an idea at this point if the clearance for the fork in the bellhousing opening is enough.
If not you can bend the fork and/or widen the opening to suit.
#3 _Tassie LJ_
_Tassie LJ_
Posted 05 September 2017 - 08:05 AM
Thanks Rexy, after talking again with Toranamuk maybe the next question should be what thrust bearing carrier have you used and what to avoid. Some have mentioned V6, just wondering what the people have used recently without any hassles or minimal. Cheers
#4 dattoman
  • 16,469 posts
Posted 05 September 2017 - 08:47 AM
What fork are you using ?
#5 _Tassie LJ_
_Tassie LJ_
Posted 18 September 2017 - 05:28 PM
Hi Dattoman, after a bit more checking  I have decided to go CRS bronze clutch fork and they supplied a thrust bearing and as Rexy states will mock up to get it right. Cheers
#6 rexy
rexy
  • 3,584 posts
  • Name:Rexy
Posted 19 September 2017 - 10:42 AM
Don't fret if it's not correct first up.
In addition to bending the fork and adjusting the pivot ball height you can get different height thrust bearings.
Attached File  IMG_3582.JPG   102.54K   4 downloads
Or different style clutch plates.
Attached File  IMG_3593.JPG   502.73K   4 downloads
I used the raised finger pressure plate to correct the clutch fork angle when I put the new drivetrain in the yellow LJ.
Was.
Attached File  IMG_3584.JPG   421.39K   4 downloads
Now is.
Attached File  IMG_3595.JPG   272.62K   4 downloads
