Steering column cover
5 replies to this topic
#1 mugginz
mugginz
  • 134 posts
  • Name:Greg
  • Car:LH Torana
Posted 05 September 2017 - 05:41 PM
Hi, time to put the steering column back together and I've hit a problem.
Wondering if anyone can tell me if the cover that sits below the coffee pot goes with the bump on top or bottom.
I really should've taken some photos before disassembly.
#2 76lxJAS
76lxJAS
  • 1,864 posts
  • Name:jason
  • Car:76 lx ss hatch
Posted 06 September 2017 - 12:38 AM
i believe the side that has the recess/angle goes to the dash side/top for clearance.
Edited by 76lxJAS, 06 September 2017 - 12:38 AM.
#3 mugginz
mugginz
  • 134 posts
  • Name:Greg
  • Car:LH Torana
Posted 06 September 2017 - 07:39 PM
Looks like you're right.  I did a test fit today and it looks correct the way you say.
Now I've got another question.  If I remember rightly, the indicator switch wiring ran under the column from the left side to the right side.  Has anyone got any pics of how it's routed from factory?
#4 mugginz
mugginz
  • 134 posts
  • Name:Greg
  • Car:LH Torana
Posted 06 September 2017 - 09:00 PM
I presume the HN1346 grease that's specified for application to the horn ring is just simple dielectric grease.  Can anyone confirm this?
Thanks.
#5 76lxJAS
76lxJAS
  • 1,864 posts
  • Name:jason
Posted 07 September 2017 - 12:06 PM
Yep dielectric should be fine..
As for the loom. What u say sounds good enough. Mind u I'm not one for rivet counting. Haha
#6 mugginz
mugginz
  • 134 posts
  • Name:Greg
  • Car:LH Torana
Posted 12 September 2017 - 09:04 AM
Sorted out the routing of the loom but had to trial fit the column to work out where the factory put things.
As for the grease, the local Holden parts guy said they just used lithium grease back in the day.  I've tried this and done a continuity test to make sure the grease didn't impede current flow and all seems good.
