Help needed 202 with triple stromburgs
13 replies to this topic
#1 Age186
Age186
  • 18 posts
  • Name:Adrian
  • Car:2 x Lj,s
Posted 06 September 2017 - 07:47 PM
G day guys and girls
Need some help just put a new scorcher coil to match my electronic dizzy on my 202 with triples
Did the bridge wires at ignition now have constant 12v at coil but car won't run have now tried to start all over with timing can get it to fire and ideal ruff but as revs drop fuel spews out of 2nd and 3rd Carby then car dies I have no idea what has been done to motor so not sure of any internals I know it is a very worked motor that run fine b4 I swapped coil and bridged wires any help much appreciated
#2 r2160
r2160
  • 712 posts
  • Name:Glenn
  • Car:2/71 LC GTR, 4/71 LC 4 'S'
Posted 06 September 2017 - 08:15 PM
Could the dissy be out 180 degrees?
#3 _macdou_
_macdou_
Posted 06 September 2017 - 08:17 PM
^^^ check what he said 👍
#4 _Bomber Watson_
Posted 06 September 2017 - 08:40 PM
Did you JUST SWAP THE COIL.
Or did you swap the coil and distributer?
#5 Age186
Age186
  • 18 posts
  • Name:Adrian
  • Car:2 x Lj,s
Posted 06 September 2017 - 08:57 PM
Swapped just the coil it had a scorcher dizzy already on it the coil that was on it was a old Bosch one that the coil lead had a screw holding it in place
#6 _Bomber Watson_
Posted 06 September 2017 - 09:18 PM
So if it was running fine and all that you changed was the coil then we can pretty well negate the chance of the dizzy being 180 out or there being an issue with the carbs or anything else in the engine.
Im guessing the new coil is either not wired correctly or faulty from new. Have you tried refitting the old coil to see what happens?
#7 Age186
Age186
  • 18 posts
  • Name:Adrian
  • Car:2 x Lj,s
Posted 06 September 2017 - 09:28 PM
No havent swaped coil back that was my next thing to try
Thinking I will just give it to a mechanic
Anyone got recommendations for a good tuner in Melbourne
#8 _Bomber Watson_
Posted 06 September 2017 - 09:29 PM
Dead set dude simple things first, if it was working before but not now try to return it to its previous state and see if it still works.
Sorry I cant give you a definite answer im just trying to walk you through the same steps the mechanic will go through sans the $120ph.
#9 S pack
  • 15,538 posts
Posted 06 September 2017 - 09:30 PM
What exactly do you mean by fuel spews out of the middle and rear carbs?
What type of carbs do you have?
A correctly functioning carburetor should not have fuel spewing out of it.
Sounds like your engine is flooding however I could be wrong.
#10 Age186
Age186
  • 18 posts
  • Name:Adrian
  • Car:2 x Lj,s
Posted 06 September 2017 - 09:45 PM
I've tried everything bomber just don't want to stuff anything up had a mate put a rod through the block with a wrongly timed 202
Yep s pack middle and rear carbs it comes out the over flow hole on the Side they are stromburgs
I to think it is flooding due to timing but can't get it to start until the timing gets to a point then the fuel spits out
#11 RallyRed
  • 7,836 posts
Posted 06 September 2017 - 10:05 PM
as per Bomber's post....start with the real simple things...
- does the HT lead from the coil go to the centre of the dizzy?
- are the plug leads on in the correct sequence?
- has the dizzy slipped, and is out to buggery?....had this once , and it was firing the spark to the cylinder with the valves still open, thus both igniting the fuel mix and pumping it back out the carb.( result was foam air filters on fire)
#12 S pack
  • 15,538 posts
Posted 06 September 2017 - 10:10 PM
Timing has nothing to do with a carburetor flooding. Fuel should not be spilling out of the fuel bowl vent holes. The float levels are set too high or the needle and seats are not shutting off the fuel supply properly.
A mate had the centre carb flooding on his XU1. The car ran fine once he got it started but getting it started was a bastard when it was stone cold.
A simple needle and seat replacement fixed the problem.
Edited by S pack, 06 September 2017 - 10:11 PM.
#13 Age186
Age186
  • 18 posts
  • Name:Adrian
  • Car:2 x Lj,s
Posted 06 September 2017 - 10:11 PM
I've taken dizzy out and started again have set timing at tds but it won't start set it at 12 btd this is where it starts fine and idles for a bit then splutters spits fuel and stops
Will have another go tomorrow and see how I go
#14 Age186
Age186
  • 18 posts
  • Name:Adrian
  • Car:2 x Lj,s
Posted 07 September 2017 - 02:10 PM
So have dropped the old coil back on today and bang started idled and runs no dramas just showed brand new coil just didn't want to work properly
Thank for all your advise guys
