Red 202; block twist and cam bearings ? help needed pse
20 replies to this topic
#1 73TORANA!
73TORANA!
  • 130 posts
  • Name:Geoff
Posted 24 September 2017 - 10:24 PM
Hi all, I am seeking some constructive thoughts to an issue I have with my red 202. In brief here is the engine specs.
Bore +60, ACL race series pistons rings and bearings. 1.5 thou big ends and 2 thou mains, starfire rods, XU1 cam (485 speco), top secret head hehe and a blue crank thats been knife edged ( mistake I know ), oh and cam bearing clearance 1.5 thou. Tripple stromberg carbs. Oil HPR30.
The problem I have was originally I had a red 202 crank when first rebuilt and ran with out issue for 500 km or so then its first real blast the engine vibrated badly between 5-6k rpm, second blast it went flat. Long story short cam bearing 2 and 3 picked up and turned.
Take 2, same thing happened and again only after a boot full. Oil pressure when hot 20psi @idle, 40@ 1500 and 60 @ 4k rpm.
Take 3, Knife edge blue motor crank ( see pix, green paint is primer) and made sure this time the cam bearing were broached? Previuosly requested as it seems maybe block twist with vibration at hi rpm may be the cause?????? vibration at 5-6k abot 70% better than red crank but still shook, hence mistake with knife edgeing ? miss guided info :( But this time it did not go flat and felt strong so I put up with the vib as I was happy with the rest of the engine and assumed the cam bearing issue was fixed.
About 10,000 odd km of spirited driving a slight knock only when hot could be heard @ idle ( 900rpm ) from about #1-2 area, oil pressure still the same as above. Slowly over time the erratic knock had become worse, just off idle it disappeared and no other sign to indicate a bearing issue. Engine perfect when cold and for about the first half hour. Knock is erratic like once every 3 to 4 revolutions or so. Suspected cam gear; changed and checked everything I could with engine in car but still the same. It did not have the typical symptoms of worn bearings.
I had enough. Pulled the engine out; all crank bearings checked with plasti gauge and were that close to the above figures and bearings look sweet so the knock still a mystery.
#2 cam bearing had picked up only very slightly but did not turn, who knows when that happened but it still span freely with no restriction and oil hole not blocked. Crank spins very freely in block, minimal friction.
So my main question here; is block twist an issue here with the cam bearings ? or just not enough cam bearing clearance for a hotty. Any one else had this problem ?
Is vibration the cause? as the motor had same clearances with the red crack that shook the rear vision mirror but it only lasted 2 boot fulls of right foot.
Getting rid of the knife edge crank and getting a race prep crank from Aus crank to get rid of the vibe
Any thoughts Ideas appreciated as I dont want to have this happen with the next build. $$$$$
#2 warrenm
warrenm
  • 2,107 posts
  • Car:1972 LJ Torana
Posted 24 September 2017 - 10:37 PM
What harmonic balancer?
What weight flywheel?
#3 73TORANA!
73TORANA!
  • 130 posts
  • Name:Geoff
Posted 25 September 2017 - 10:56 AM
Hi Warrenm,
Fly wheel is a steel Yella terra and the balancer is a B&M 4.1 kgs. I did forget to mention #5 cylinder has had a re sleeve and JP/crow cams helical timing gears.
thx.
#4 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 25 September 2017 - 11:09 AM
Hi Warrenm,
thx.
Funny you say B&M balancer... I had a very similar knock to the one you described... turned out the B&M 4.1kg balancer flogged out the keyway so it had a bees dick of play over the crank snout, which was causing the knock at idle.
As you say you pulled the engine down and the bearings were all good (the last time), perhaps inspect for movement of the balancer- this has nothing to do with your previous issue of picking up bearings but it may give some answer as to your last 'mystery' knock.
#5 73TORANA!
73TORANA!
  • 130 posts
  • Name:Geoff
Posted 25 September 2017 - 07:42 PM
Thanks LC, I had a real close look this arvo and cant really see any witness marks on the snout to suggest any movement although the balancer has been off numerous times on this and my old engine over the years; the key way is tighter if I put it on backwards by hand so you may be onto something. Just hard to confirm.
Did you only get the knock when hot? as mentioned its erratic like knock knock...........knock....knock knock........knock.
Was your balancer hard to pull off or did it come off the crank easy.? Mine is requires a bit of effort to remove.
I also had a good look at the multi key way crank gear. Any one had any issues with these walking around or JP gears in general
Any recommendations on a good balancer.
#6 _Agent 34_
_Agent 34_
Posted 25 September 2017 - 07:56 PM
Geoff,
that sequence of events seems strange, I know some NC guys that still run a red crank but put a fluid damper up front ( similar to warren ) and a pretty light fly wheel , but run a girdle for some mid support.
I will say that there is some CAMS that have a steep ramp and warren may be able to expand on this, but a steep ramp sounds noisy on the lifters if it's a solid.
Lets not get carried away, a stout built 6 should handle a bit of punishment with out - a fully baffled sump, lifter bores bushed , roll pinns in the push rods -
It seems that Oil pressure or lack of it is not the issue, otherwise a big failure would be on the cards and this has not happened apart from the first event.,
I spoke to Mike Dwyer ( heres the leveler ) engines in brookvale - mikes 78. I spoke about line boring which is what you are refering to as the cam bearing is out and catching, YOU can line bore the cam and there is possibly and issue with the tunnel, but maybe fitting the cam shells may be the issue.
I sort of get the whole idea of GMH was not a precise science , but the cam  tunnel and the main caps were once bored straight by a machine shop and whilst there maybe some very slight variation it was done straight at some time. AND that motor run for some time without a big failure.
It could also be a " per detonation " of a cylinder or two that is making the knock.
If you are running the engine upto and under 6500 on the odd occasion and not fluctuating through the rev range like a race engine then it's seems hard to determine this issue.
I'd go;
is the cam ramp steep or too steep - how much HP are you making out of the engine ?
fly wheel -
clutch
front balancer
try and balance all of the above if out to gether
it's the best ive got - but somethings wrong to chew out the cam bearings on a streeter with a red crank - unless they were fitted wrong ( or off center )
dont waste your money on a race preped crank - it's not the cause of your issues. donate the money to your local community mens  mental health scheme. I still run a knife edge and most blokes do.l
Edited by Agent 34, 25 September 2017 - 08:01 PM.
#7 73TORANA!
73TORANA!
  • 130 posts
  • Name:Geoff
Posted 25 September 2017 - 10:18 PM
Thanks Grant,
When I fitted the Cut back/knife edge crank( pix above ) a few years back and had crank, flywheel and balancer done together and had the rod weights matched.
You say knife edge, do you mean counter weight leading edge machined while leaving most of the counter weight or cut back knife edge like mine? Ive heard both styles called the same.
I did drop the timing back while playing around but to no avail.
The cam is a std XU1 grind with 428 lift, 308 valves with about 220 lbs spring pressure at full cam lift.
Shes no Bathurst winner but on the dyno; 286ft lbs tq and 185rwhp.
Cam bearings with the red crank only failed after a heap of right foot which is why I though of twist but as its not a big hi po motor it seems maybe bearings too tight or off center as you say.
Time for a different block ???
#8 _Bomber Watson_
Posted 25 September 2017 - 10:24 PM
Im sorry but there is no way in hell a 6krpm engine has caused the issues you are facing without any of the issues spelled out above being a major factor.
Clearly there has been some major machinist issues going on here.
#9 73TORANA!
73TORANA!
  • 130 posts
  • Name:Geoff
Posted 25 September 2017 - 11:00 PM
Yep was kinda thinking the same as its no big HP donk and thousands of reds have been built and raced without these issues..... massive sigh....... start again with a different machinist im thinking
#10 S pack
  • 15,539 posts
Posted 26 September 2017 - 07:19 PM
Makes you wonder if they even bothered to line ream the new cam bearings.
#11 73TORANA!
73TORANA!
  • 130 posts
  • Name:Geoff
Posted 26 September 2017 - 07:53 PM
G'day S pack,
Yeah I was suspicious of that so when the knife crank was fitted I made sure it was done and when the motor was pulled to investigate the clunk an inspection of the cam bearings showed #2 had ever so slightly picked up some time during the 10-15000km so maybe not enough broaching. Incidentally I could only get a 1.5 thou feeler between cam and bearing, not the right way to measure but did not have correct tool will get machinist to check.
Might have an answer to clunk. will post shortly.
Edited by 73TORANA!, 26 September 2017 - 07:54 PM.
#12 73TORANA!
73TORANA!
  • 130 posts
  • Name:Geoff
Posted 26 September 2017 - 09:49 PM
Thx to the suggestion by LC-GTR re the balancer I revisited the snout area; I had an old std balancer that had sloppy key way, pushing on a little by hand and rotating back and forth I could simulate a similar type clunk and funly enough the clunk appeared to be coming from #2-3 area.
I had a more thorough inspection where the multi key way gear sits and it appeared to be only contacting about 10% of its potential seating area by the witness marks on the gear and snout. Next I checked my trusty old 186 and its gear showed a footprint of about 90% on gear and snout. Same JP gear set all be it 20 years older.
The key on the knife crank looks good but the gear maybe moving on the crank; see pix, I cant measure anything but taking a pix through a magnify glass then zooming in it does look like some movement is evident ?? Gears have 9 thou backlash, may be the hi rpm vibe along with the back lash has worked the gear. Am I dreaming ? Both crank snouts measured up the same.
Any thoughts ? Has anyone had any or know of any issues with multi key crank gears
First pic is the old 186; 2nd and 3 rd are the 202 crank and gear
#13 warrenm
warrenm
  • 2,107 posts
Posted 27 September 2017 - 12:25 AM
You are using a 4kg balancer, correct? Does the crank have a retaining bolt in the balancer end? If not, the balancer may have moved slightly allowing the gear & balancer to flog on the crank snout, I have seen heavy balancers move because it wasn't tight enough fit on the snout, but the snout or the balancer usually is galled. The marks on the gear look about normal, it is an interference fit.
#14 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 28 September 2017 - 09:31 AM
Yes my damaged HB was hard like normal to get off.. i tested the flogged out balancer by puting it on to home position than cranking over the HB forward and backward and you could feel some slight movement (without moving the crank). Because the HB has a long keyway it was only damaged on keyway in home position.. hence it feels tight in all other positions other than home.
When diagnosing the knock it sounded like a bottom end knock.. with my stethoscope it deadset sounded like number 3 main. The knock was resonating along the crank like a bell. Sometimes all is not what it seams!
Nonetheless this may not be the source of your mystery noise but it might be worth looking into, especially if your bearings look ok.
#15 73TORANA!
73TORANA!
  • 130 posts
  • Name:Geoff
Posted 28 September 2017 - 10:16 AM
Mate thats exactly what it sound like; everyone that heard it said main bearing and yeh #3, but it had no other bearing symptoms and they look brand new with 1.5 thou clearance across all 6. Thanks you so much LC for your input, most helpfull ,  Visually the key and key way look fine but I will replace the key and sus the key slot in the balancer and try to measure it up. Will refit to crank and investigate, might be hard as engine now on a stand. Oh and will tap a thread in the snout. I am toying with the idea of getting rid of the knife edge crank in favour of a normal blue black crank from crankshaft re builders ( Aus crank ) only reason in an attempt to stop the vib at 6k rpm.... any thoughts.
Cheers and thx again
#16 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 28 September 2017 - 12:23 PM
Dont thank me yet mate I could be barking up the wrong tree.. to be honest, as Warren said, you would typically see some galling on the crank snout if the balancer has been moving.. plus you shoukd be abke to feel the play when the HB is in the home position...
Good luck mate
#17 73TORANA!
73TORANA!
  • 130 posts
  • Name:Geoff
Posted 28 September 2017 - 12:48 PM
Hey LC,
I put the HB and timing gear back on the crank and locked the crank up as its in the engine stand but no sign of movement so fitted 2 bolts to the HB ( for turn / leverage purposes) and heated the HB, block and crank. Now I could get a very slight movement if I used a crow bar between the 2 bolts applying fwd , backward rotations. every thing was hot too touch. Thinking back when I could here the knock, if I turned engine off and re started only 3 mins or so later the knock was gone and would slowly come back, heat soak? But I recon I have the same issue as you had and it was more noticeable after I changed the cam gears and put it all back together.
#18 73TORANA!
73TORANA!
  • 130 posts
  • Name:Geoff
Posted 10 April 2018 - 02:10 PM
Gave the bottom end a freshen up, new crank and  bearings etc new cam gears, same cam with refaced lifters, cam bearing measured all good. Had block line bored to bring cam gear  tooth clearance back into spec and a new romac HB bolted on, new slugs, the lot. Engine has never been this smooth and feels and sounds really nice until it gets hot then the dreaded knock came back. WTF. Oil press 25 -30 @ 900rpm hot   50 @2500 hot and 60+ @ 6k rpm
Cam end float was 4 thou, too much, not enough ? within spec. Only things didnt change was Fuel pump, Dizzy and oil pump oh and the cam it self but all these were in really good nick. Over it. The valve spring are quite heavy and maybe causing cam end float chatter ????
Time for a 2JZ GTE hehehe
Edited by 73TORANA!, 10 April 2018 - 02:12 PM.
#19 warrenm
warrenm
  • 2,107 posts
Posted 10 April 2018 - 11:28 PM
.004" is ok for cam end float.
#20 hip6
hip6
  • 198 posts
Posted 11 April 2018 - 06:59 AM
If they're hyd lifters,they could be bleeding down once they're properly warm making the noise you're describing...for reals.
#21 Torana 202
Torana 202
  • 23 posts
Posted 11 April 2018 - 08:40 PM
Have experienced what Hip6 described with hydraulic lifters and heavy valve springs.
Not my car :
