Hi all, I am seeking some constructive thoughts to an issue I have with my red 202. In brief here is the engine specs.
Bore +60, ACL race series pistons rings and bearings. 1.5 thou big ends and 2 thou mains, starfire rods, XU1 cam (485 speco), top secret head hehe and a blue crank thats been knife edged ( mistake I know ), oh and cam bearing clearance 1.5 thou. Tripple stromberg carbs. Oil HPR30.
The problem I have was originally I had a red 202 crank when first rebuilt and ran with out issue for 500 km or so then its first real blast the engine vibrated badly between 5-6k rpm, second blast it went flat. Long story short cam bearing 2 and 3 picked up and turned.
Take 2, same thing happened and again only after a boot full. Oil pressure when hot 20psi @idle, 40@ 1500 and 60 @ 4k rpm.
Take 3, Knife edge blue motor crank ( see pix, green paint is primer) and made sure this time the cam bearing were broached? Previuosly requested as it seems maybe block twist with vibration at hi rpm may be the cause?????? vibration at 5-6k abot 70% better than red crank but still shook, hence mistake with knife edgeing ? miss guided info :( But this time it did not go flat and felt strong so I put up with the vib as I was happy with the rest of the engine and assumed the cam bearing issue was fixed.
About 10,000 odd km of spirited driving a slight knock only when hot could be heard @ idle ( 900rpm ) from about #1-2 area, oil pressure still the same as above. Slowly over time the erratic knock had become worse, just off idle it disappeared and no other sign to indicate a bearing issue. Engine perfect when cold and for about the first half hour. Knock is erratic like once every 3 to 4 revolutions or so. Suspected cam gear; changed and checked everything I could with engine in car but still the same. It did not have the typical symptoms of worn bearings.
I had enough. Pulled the engine out; all crank bearings checked with plasti gauge and were that close to the above figures and bearings look sweet so the knock still a mystery.
#2 cam bearing had picked up only very slightly but did not turn, who knows when that happened but it still span freely with no restriction and oil hole not blocked. Crank spins very freely in block, minimal friction.
So my main question here; is block twist an issue here with the cam bearings ? or just not enough cam bearing clearance for a hotty. Any one else had this problem ?
Is vibration the cause? as the motor had same clearances with the red crack that shook the rear vision mirror but it only lasted 2 boot fulls of right foot.
Getting rid of the knife edge crank and getting a race prep crank from Aus crank to get rid of the vibe
Any thoughts Ideas appreciated as I dont want to have this happen with the next build. $$$$$
