73 Brisbane lj gtr interior
#1 _Redhiker54_
Posted 05 October 2017 - 08:24 AM
Posted 05 October 2017 - 04:06 PM
50X is blackHi , I'm trying to work out what the interior, seat belts door trims ect should look like has 50 x trim code thanks
Posted 05 October 2017 - 08:58 PM
50x is black long grain trim mate same as roebuck in the chrome door trim rectangle area, but smoother looking vinyl
Seat belts are all the same for brisbane lj & black webbing.
Seats will be all long grain vinyl no inserts if it only says 50x
#4 _Redhiker54_
Posted 07 October 2017 - 11:56 AM
Posted 07 October 2017 - 01:46 PM
LJ XU1 door trims
#6 _Redhiker54_
Posted 07 October 2017 - 03:01 PM
Posted 07 October 2017 - 05:02 PM
An "XU1" is a GTR, so yes, but the GTR badges are not fitted.
Bazza
Posted 07 October 2017 - 05:45 PM
Thanks for the help, can anyone confirm that I need big buckle seat belts.My door trims are just black no silver detailing if anyone has a picture of what it should look like that would be great .
Buckle size in brisbane "does not" change like in the Adelaide cars, so yes big buckle if you prefer to call them that.
The door trim on the red xu1 Dave posted has the smoother "long grain" 50x style black vinyl, as Bazza has stated, the door trim design is the same for "gtr" & "gtr xu1", apart from the "gtr" only has a gtr badge in both door trims, in the gtr xu1 the badge was not there. Gary.
Posted 07 October 2017 - 06:29 PM
Hi
#10 _Redhiker54_
Posted 07 October 2017 - 07:49 PM
#11 _Redhiker54_
Posted 08 October 2017 - 06:32 AM
#12 _Redhiker54_
Posted 08 October 2017 - 06:37 AM
Posted 08 October 2017 - 07:50 AM
More questions reguarding the trims , I know I have lots . I read some where on here that the ashtrays on a lj is a different size to lc is this correct as my trims don't have these either . Also no carpet on bottom , trying to gather the correct pieces and info to have them retained. Thanks
Yes the LJ ashtrays are larger than the LC item. Also LJ are black plastic and LC are chrome plated diecast alloy.
LC does not have ashtrays in the front door trims, only front occupant ashtray is in centre of dash pad.
AFAIK the LJ ashtrays are the same as HQ.
All GTR & XU1 door trims (LC & LJ) have carpet on bottom of door trims but not on the rear trims.
Edited by S pack, 08 October 2017 - 07:54 AM.
#14 _Redhiker54_
Posted 08 October 2017 - 07:58 AM
Posted 08 October 2017 - 08:06 AM
Stitched up at home or in an auto upholsterers shop to attempt to replicate an XU1 trim.
Wrong vinyl on the trim for a 50x trimmed LJ and looks like the Landcruiser roebuck type vinyl.
The vinyl garnish glued to the top of the door looks like there is a series of dents in the door under the vinyl
Edited by S pack, 08 October 2017 - 08:12 AM.
Posted 08 October 2017 - 08:21 AM
Best bet Mal is to chuck your existing trims and order a set from a reputable manufacturer like Winner Products or Dash Original etc.
#17 _Redhiker54_
Posted 08 October 2017 - 10:09 AM
Posted 08 October 2017 - 12:25 PM
#19 _Redhiker54_
Posted 12 October 2017 - 05:59 AM
Posted 12 October 2017 - 06:41 AM
Bazza
#21 _Redhiker54_
Posted 12 October 2017 - 07:02 AM
#22
Posted 12 October 2017 - 08:51 AM
#23
Posted 12 October 2017 - 09:58 PM
IMG_8036.jpeg 112.33K 8 downloads
One thing I noticed is the XU-1 trims are puffy, more padding in the centre section of the chrome trim than outside the trim.
My GTR trims are an even padding all over. This maybe bad reproductions but interested if this is a true difference between GTR and XU-1?
Marty
#24
Posted 12 October 2017 - 11:03 PM
Marty, something caught my attention in the photo of your interior. The handbrake cover has a "collar" at the end which looks like it is stitched vinyl. Is this correct for 73 interior as mine has a separate rubber ring slid over the handbrake cover, which had me thinking it was a factory original thing?
#25
Posted 13 October 2017 - 07:44 AM
The wide black rubber ring is correct for all LC/LJ/TA (excl 4dr with bench seat dash mounted handbrake)
Edited by S pack, 13 October 2017 - 07:44 AM.
