replace diff housing upper bushes on banjo diff
11 replies to this topic
#1 tsn007
tsn007
  • 1,010 posts
  • Name:Tony
  • Car:LX hatch, LX sedan
Posted 05 October 2017 - 05:20 PM
how do you replace the upper diff bushes on the diff housing
Lh Banjo
#2 308 Sunbird
308 Sunbird
  • 963 posts
  • Name:Stuart
Posted 05 October 2017 - 05:54 PM
Just done this Tony- bastard of a job.
Basically you need to bash them out using anything you can find.
It's hard to get a swing at them but a combination of big hammer, WD40, cold chisel, and perseverance
and you will eventually win.
#3 _hutch_
_hutch_
Posted 05 October 2017 - 06:21 PM
I got mine out easy as,I used an air chisel,I made up a half moon spacer to go in between the outter sides of the arms to stop them collapsing and used a good vice to pull them in
#4 tsn007
tsn007
  • 1,010 posts
  • Name:Tony
ok thanks
what about putting new ones in ?
#5 _hutch_
_hutch_
Posted 05 October 2017 - 06:24 PM
Adding to the above,if you put the chisel along the same axis as the bolt it shrinks the bush,hope that makes sense
As above,I replaced the whole lot,easy as,I used a piece of pipe cut in half,to form a U shape doesn't need to be any thing super accurate just enough to stop the sides collapsing
Edited by hutch, 05 October 2017 - 06:27 PM.
#6 _hutch_
_hutch_
Posted 05 October 2017 - 06:28 PM
Biggest issue I had was not scratching the new paint lol
#7 tsn007
tsn007
  • 1,010 posts
  • Name:Tony
Posted 05 October 2017 - 06:45 PM
any pictures
#8 _hutch_
_hutch_
Posted 05 October 2017 - 07:38 PM
I done mine about 4 years ago
#9 76lxhatch
  • 7,142 posts
Posted 06 October 2017 - 04:37 AM
Hammers and chisels!? All you need is a length of threaded rod and a couple of nuts with with a few choice bits of scrap pipe/steel to make a puller - can be used to remove and install without damage.
#10 Statler
  • 6,281 posts
Posted 06 October 2017 - 08:12 AM
+1 for the air chisel.
Hammer the 'small' end in 2 or 3 places, ( the old bush will deform )  put the bit behind it & they drift straight out.
#11 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 06 October 2017 - 04:23 PM
+1 to what 76lxhatch said. Easy and effective.
#12 rexy
rexy
  • 3,579 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 06 October 2017 - 04:47 PM
Made mine up out of shed scrap.
Attached File  IMG_0492.JPG   409.88K   7 downloads
Attached File  IMG_0493.JPG   159.19K   5 downloads
Attached File  IMG_0496.JPG   530.51K   5 downloads
