Hey im putting my car back together and only had a shell to start with so i i have no pedals or brackets. Im up too booster/master stage and my question is are the factory lx auto + acclerator setups universal in other holdens (to source) and will this work with an ls engine setup or should i go new? Thanks Nathan.
Need help setting up brake+ acclerator pedals for auto in LX
Posted 24 October 2017 - 01:04 PM
Posted 24 October 2017 - 01:15 PM
Accelerator pedal are torana specific also with different pedal for 6 or v8.
Posted 24 October 2017 - 03:03 PM
How is the accelerator pedal different between 6 or 8 ???
I thought it was only the length ....v8 being longer
Posted 24 October 2017 - 03:43 PM
Just had a look at my LX parts manual and it lists accelerator pedal as same for all. PN 2815916. Different bracketry between manual and auto to allow for detent actuating switch. Can't comment on other models. Cheers Ron
Posted 24 October 2017 - 05:48 PM
Posted 24 October 2017 - 06:24 PM
^ yes, just had a further look at the parts catalogue and lists different levers/pivot for 6 & 8cyl. I presume that also corresponds with the different holes in the bracket that the lever bolts to? Cheers Ron
Edited by Cook, 24 October 2017 - 06:25 PM.
Posted 24 October 2017 - 07:01 PM
22555723_10214139710148274_2923252555768501404_o.jpg 42.44K 3 downloads
Posted 25 October 2017 - 06:36 AM
Hi Toranamat69. Are you able to do a quick measure of the distance from the top of the lever to the pivot point of the V8 pedal. I'm starting to wonder if I have a 6cyl one at present. Cheers Ron
Posted 25 October 2017 - 07:13 AM
Posted 25 October 2017 - 07:15 PM
The v8 pedal is 182mm from the top to the centre of the pivot. This is 22 mm different to the 6 pedal as close as I can measure..
Posted 26 October 2017 - 07:35 AM
^Thanks for that. Now I will have to find mine and see what I have. Fingers crossed. Cheers Ron
Posted 26 October 2017 - 04:34 PM
Posted 26 October 2017 - 04:51 PM
Going by the above pic by Toranamat69 is there a differance between 6 cylinder and V8 pedals or is it just the upper and lower position on the floor bracket ???
Yes i know the V8 cable is longer than the 6 cylinder one
And what do people do when converting from 6 to V8
Thanks Kevin
#14
Posted 26 October 2017 - 10:29 PM
Posted 27 October 2017 - 04:41 AM
Brad that is the same spot as my 6 cylinder that i am converting to v8
so there must be a different pedal between 6 and 8
#16
Posted 27 October 2017 - 08:01 AM
#17
Posted 28 October 2017 - 07:52 AM
my 6 cylinder is in the bottom hole
where do you buy the V8 pedals ???
