XU1 Booster Vaccum Hose Connection
5 replies to this topic
#1 ChrisLC
ChrisLC
  • 53 posts
  • Name:Chris
  • Car:1971 LC Four Door S
Posted 14 November 2017 - 08:10 AM
Years ago, I got rid of the PVC pipe between rocker cover and the T connection used on the triple CD's, and replaced it with a pipe (the old "walking stick"). I blocked the middle manifold hole that the booster was connected to, and connected the booster to the T connection previously used by the PVC hose. Looking for opinions, is there anything wrong with this? Restoring the LC and do not want to repeat any past mistakes.
#2 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,080 posts
  • Car:ɐuɐɹoʇ
Posted 14 November 2017 - 09:20 AM
Hi
I believe that by using the old 'hockey stick" crankcase venting , the emission control ADR (as specified for that vehicle) would no long be complied with.
Bazza
#3 ChrisLC
ChrisLC
  • 53 posts
  • Name:Chris
Posted 14 November 2017 - 03:01 PM
Hi
Bazza
Thanks, I realize that Bazza. I may not be putting the hockey stick back on.
#4 grumpy xu1
grumpy xu1
  • 1,460 posts
  • Name:Gary
  • Car:lj xu1
Posted 14 November 2017 - 05:13 PM
The pcv line can get oil back through it, hook the pcv up normally "test it first" I'm pretty sure that you can pull them apart & service them anyway. & fit the brake hose back in the normal spot. If you're really concerned about the pcv, you can run it via a catch can on the way, pcv to catch can, catch can to t junction. Throw the walking stick & the foam filters. Gary.
#5 ChrisLC
ChrisLC
  • 53 posts
  • Name:Chris
Posted 15 November 2017 - 04:27 PM
Thanks Gary, yes the foam filters are going, as is the walking stick. Thanks.
#6 grumpy xu1
grumpy xu1
  • 1,460 posts
  • Name:Gary
  • Car:lj xu1
Posted 15 November 2017 - 06:33 PM
Sounds good mate
