Heights of A9X Bonnet Scoops available
9 replies to this topic
#1 eldo
eldo
  • 1 posts
  • Name:Ian Eldridge
  • Car:LX Torana Hatchback
Posted 20 November 2017 - 07:26 AM
Morning
Looking for info on what different heights of A9X bonnet scoops are available out there.................
I currently have a 100mm height scoop which is too low for my cold air intake set up due to the height of my inlet manifold setup and the 130mm is way too high.
Does anyone do a scoop in between 100mm and 130mm?
Eldo
#2 myss427
myss427
  • 1,636 posts
Posted 20 November 2017 - 11:26 AM
Only ever seen after market Camaro scoops that high and the profile is way different.
#3 Shiney005
  • 9,029 posts
  • Car:Toyota Mirai
Posted 20 November 2017 - 11:40 AM
There are a few guys who make the "reverse cowl" bonnets at various heights. But they look nothing like the bolt on Torana scoop.
Attached File  39Capture.JPG   76.7K   10 downloads
#4 CI 0308
CI 0308
  • 736 posts
  • Car:77 LX SS, VX SS
Posted 20 November 2017 - 12:04 PM
My car originally had this style fitted but I have no idea what it is.
#5 TORLX8
TORLX8
  • 586 posts
  • Name:Campbell
Posted 21 November 2017 - 07:17 AM
My SS had that style scoop with the raised ridge at the back of it too.
Wasn't even mounted correctly at the back of the bonnet. Was about 50mm forward.
Sent from my Moto G (5) using Tapatalk
#6 Rockoz
Rockoz
  • 3,961 posts
  • Name:Rob
Posted 21 November 2017 - 07:20 AM
Grinder and fibreglass and tape and modify a normal one might be an option
#7 CI 0308
CI 0308
  • 736 posts
Posted 21 November 2017 - 08:15 AM
Don,t worry, It was the first thing that got fixed!!!!
#8 koalasprint
koalasprint
  • 295 posts
  • Name:Steve
  • Car:LX SS Hatch
Posted 21 November 2017 - 10:29 AM
Hi Eldo, I had a fibre glass scoop on my Hatch, it was 110mm at the windscreen, but it was about 200mm longer than the A9X replica scoop, so the point where the curve starts was further forward. You may be able to find someone that still makes them. I sold mine for a replica scoop as I didn't like the way the larger one looked. I have a high rise intake manifold, 1 inch carby spacer, 14" (large) air cleaner, standard Torana engine mounts and still have clearance to my scoop, Is there anything you can do to modify the cold air intake or go to HQ engine mounts? The HQ mounts drop the motor by 8mm.
This is what it looked like.
#9 StephenSLR
StephenSLR
  • 6,707 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 27 November 2017 - 10:31 AM
I believe there is only one height for the A9X scoop. Back in the 80's, one company in Sydney was selling what they called A7X scoops which had a lower profile but it was an aftermarket product, I'm sure many fibreglass companies made copies that aren't exact to original.
Those ribbed scoops that are trendy these days shouldn't be called A9X scoops imo.
s
#10 jass_hatch
jass_hatch
  • 53 posts
  • Name:Jason
Posted 14 December 2017 - 08:00 PM
Try Grem at Queensland Custom Fibre (on facebook). Based in Redcliffe QLD. Makes a lot of Torana accessories like scoops/flares. He may be able to make something to suit your needs
