best fuel
16 replies to this topic
#1 _lj tory_
_lj tory_
Posted 23 November 2017 - 07:39 PM
need some advice on fuel please, got a new torana couple of weeks ago, had a full tank of fuel, filled up with 98 once,drive ok, then i put it in to panelbeaters where it sat for a week, when i got it back it coughed and spluttered most of the way home, gave it a good gutful and it seemed to fix it. filled up again with 98, then it has sat in the shed for a week, drove it again today and it was terrible, drove it coughing and spluttering for 10 mins, my question is , i think it is the fuel mix so do i need to add anything to the fuel, or is it possibly just something else
#2 Bigfella237
  • 4,371 posts
Posted 23 November 2017 - 09:40 PM
Sounds like you may have water in the fuel?
It's not so bad when it's all stirred up, especially with some ethanol content (which absorbs water), but after it sits for a week the water (being heavier than petrol) settles to the bottom of the tank where the fuel pickup is.
Normally I'd say it'd have to be the petrol station that has water in their tanks, but as you've only had the car a couple of weeks you don't have a good baseline to say for sure?
The proper way to fix this is to drain and remove the fuel tank to clean and inspect it, possibly use one of those "treatments" that coat the inside if it's rusty, then flush the fuel lines and change the filter(s).
Or the bush mechanic's method would be to run the tank down until it's under a quarter then add a litre of metho. But don't let the metho sit in the tank for any length of time, once it's in, go for a drive to slosh it around and run the tank as dry as you dare, if you've got a good battery and a jerrycan of petrol with you, you could even run it out altogether, then fill it up again WITH GOOD CLEAN FUEL.
BP Ultimate is my first fuel of choice, these days I'll drive out of my way to find it. If you look at the composition of all the different brands of fuels in their MSDS you'll see it has almost no additives (see BP Ultimate sheet here) but it comes down to your local area and what kind of choice you have too. Caltex Vortex 98 would be my second choice (MSDS here).
Shell V-Power on the other hand...
Contains Benzene, CAS # 71-43-2.
Contains Toluene, CAS # 108-88-3.
Contains Ethylbenzene, CAS # 100-41-4.
Contains n-Hexane, CAS # 110-54-3.
Contains Xylene (Mixed Isomers), CAS # 1330-20-7.
Contains Naphthalene, CAS # 91-20-3.
Contains Cyclohexane, CAS# 110-82-7.
Contains Tri-methyl-benzene (all isomers), CAS# 25551-13-7.
May be dyed. Red.Purple.
...I would have to be REALLY desperate to use!
#3 _lj tory_
_lj tory_
Posted 24 November 2017 - 04:06 PM
thanks mate, i'll have a go at the bushmans way i reckon and see what happens, i got petrol at a different servo yesty just to see what happens
thanks again
#4 TORLX8
TORLX8
  • 586 posts
  • Name:Campbell
Posted 25 November 2017 - 08:38 AM
My Dyno guy recommends BP 98 also.
Sent from my Moto G (5) using Tapatalk
#5 lawn bowls
lawn bowls
  • 262 posts
  • Car:72 lj 4 door
Posted 25 November 2017 - 08:20 PM
i like mobil 98.
#6 StephenSLR
StephenSLR
  • 6,707 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 27 November 2017 - 10:12 AM
Either that or dirt in the tank, maybe a clogged filter or even your fuel pump could be on its way out. Check around the fuel pump for leaks. Mine would leak upon start up but then settle down after a minute or two. When I'd reverse out of the garage I saw fuel on the floor and thought it was the hoses, I'd tighten them and it'd be alright but it was a crack in the pumps diaphragm, it'd expel fuel that built up overnight upon start up.
s
#7 _71lc_1JZ_
_71lc_1JZ_
Posted 27 November 2017 - 02:41 PM
have a look on youtube at a video call "should I use hi octane premium petrol, and what is octane rating
very good video we are all taking in by the big marketing
#8 StephenSLR
StephenSLR
  • 6,707 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 27 November 2017 - 02:51 PM
When I saw it was this gronk I have my doubts any of it's true.
s
#9 _71lc_1JZ_
_71lc_1JZ_
Posted 28 November 2017 - 11:55 AM
Im no expert but if its on You tube or face book it has to be true??? right???? I had and don't be mean haha 03 xr6 that I run on 91 95 98 also ethanol and there was no performance increase or loss fuel consumption was same for all fuels... may be more noticeable in smaller turbo cars
Edited by 71lc_1JZ, 28 November 2017 - 11:56 AM.
#10 _lj tory_
_lj tory_
Posted 09 December 2017 - 11:26 AM
#11 _lj tory_
_lj tory_
Posted 09 December 2017 - 11:35 AM
thank you thank you thank you, i did the bushmans method as i was a little uncertain about removing the whole tank. i drove her to 0 on the gauge, filled with 1 litre metho, then drove around my paddock-for a hour!!- she stopped and started a few times over the hour until finally she stopped and wouldnt start. i made sure i kept trying to start her and pumping the pedal to get rid of all petrol. then i put in  bp 98, and got her going again. on the way back to the house she stopped again twice and it didnt seem like there was any difference. put her in the shed for the day , tried to start her the next day and she wouldnt idle just kept stalling, left it, done the same the next day, same thing, no idle, tried the 3rd day, stalled a few times, finally got an idle,so i took her down the road, one miss in 1st gear and that was the end of it and now she is running perfectly again!!
thanks for your help
Edited by lj tory, 09 December 2017 - 11:36 AM.
#12 Bigfella237
  • 4,371 posts
Posted 09 December 2017 - 12:57 PM
No worries, it certainly wouldn't hurt to change the fuel filter(s) now too.
#13 _lj tory_
_lj tory_
Posted 12 December 2017 - 08:41 PM
thats what i thought too, but i couldnt find one on the car anywhere, so was wondering if i should put one on there myself
#14 _Bomber Watson_
Posted 12 December 2017 - 09:41 PM
STandard the dar didnt have a replaceable filter.
By all means fit one.
I frOcking hate that dickhead from car advice but that vid on octaine linked above is a gem, and he's for the first time im his carrear dead on the money.
#15 Bigfella237
  • 4,371 posts
Ah okay, that was probably half your problem to begin with then!
If it's just the standard mechanical fuel pump and carby setup (not some wiz-bang high pressure electric job) then something like your typical Ryco Z14 would be ideal.
Just mount it in the engine bay between the steel fuel line and the fuel pump. You can either cut a section out of the original rubber hose or (from memory) they come with a couple of short pieces of hose and some spring clamps.
If I were you, I'd buy two while I was there and throw the spare in the glove box, it might take a couple of filters to catch all the crap if the tank was really dirty?
#16 StephenSLR
StephenSLR
  • 6,707 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 13 December 2017 - 01:32 PM
I frOcking hate that dickhead from car advice but that vid on octane linked above is a gem, and he's for the first time im his career dead on the money.
I decided to give it a listen, he could've condensed that so much but yeah, I use 95, the local carb specialist who's been involved in racing for many years told me to come back after I've run at least a tank full of 95 to flush out any 98, he tuned it and told me to stick to 95.
s
#17 _cobbadog_
_cobbadog_
Posted 21 December 2017 - 03:54 PM
There has been a great deal of good advise offered. I mainly restore and play with our Vintage Tractors. If I don't completely fill the petrol tanks after play I get condensation in the tank which then can end up in the engine and we all know what happens if too much water gets inside.
I always use and run 98 with no problems and on the old engines that have not been rebuilt I use an additive to help the valves last. A fuel filter is a good insurance policy and I have fitted one between the chassis and the fuel pump so it saves water and dirt from getting into the pump and carby.
