2 Door rear quarter window channel seals
29 replies to this topic
#26 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,463 posts
  • Name:MAZ
  • Car:72 LJ SL SEDAN. 69 LC S 2 DR SEDAN
Posted 04 May 2018 - 05:43 PM
Good job Paul..you done well getting that in .
Paul (housecat1977) had probs with it being that thick
The powder on butyl tape must work wonders...
Take ya long..
#27 Indy Orange
Indy Orange
  • 1,362 posts
  • Name:Paul
Posted 04 May 2018 - 06:04 PM
About 3 hours all up Maz,the beauty of that rubber is you can stretch it and it becomes thinner as its stretched,I still had to push the frame in around the glass though.
#28 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,463 posts
  • Name:MAZ
Posted 09 May 2018 - 12:11 AM
Def worth the time to do it properly..good stuff.
This is definately worth pinning.
#29 LC870
LC870
  • 264 posts
Posted 18 May 2018 - 03:12 PM
When  you  use  the  glass  setting  tape  it  is  known  as  semi  cures  rubber .
The  trick  is  to  immerse  the  rubber  in  kerosene  before  use .
It  the  becomes  super  slippery  and  then  goes  around  the  corners  perfectly .
The  glass  slides  straight  straight  in  to  the  frame  with  no  effort  at  all .
Once  the  kero  dries  the  rubber  it  them  becomes  cured .
Regards  LC870
#30 Indy Orange
Indy Orange
  • 1,362 posts
  • Name:Paul
Posted 19 May 2018 - 12:12 AM
Regards  LC870
I didn't use Kero,I didn't need to ,it went in ok without it.The rubber tends to shrink back and gives it a tight fit.
