Hi,
I need to replace the drivers side floorpan in my LC
I have bought a replacement from Rare Spares, but as I haven't done this before I wanted to make sure I'm on the right track
I was thinking I'll sit the floorpan in the car so it sits on these 'humps' on either side of the rear of the replacement pan properly then mark out a cut out line all the way around the floorpan. Then I'll make another cut out line about an inch inside that line then cut that out?
That will leave me a decent margin for error.
Then I can place the replacement back in and hopefully it sits closer on the rail as it currently sits too high and leaves a gap.
I could then trim a bit more out and get it to sit tighter.
I'm a novice welder so I will most likely leave an overlap instead of trying to butt up the edges.
Am I on the right path with how to do it?
