hi all need a bit of help. installing water temp gauge and as per wiring diagram red wire to 12v ignition switch green wire to sender unit orange wire to light and black wire to earth. in the written part it states connect red wire to a switched 12vositive source that is turned on and of with the ignition switch. this is on my lc torana and I need to know what is the best place to pick up this source/wire.thans for any help gary.
water temp gauge
_gazza123_
, Dec 21 2017 11:14 AM
1 reply to this topic
#1 _gazza123_
Posted 21 December 2017 - 11:14 AM
Posted 21 December 2017 - 12:45 PM
Probably back of the fuse panel.
Find the radio supply or windscreen wiper supply.
Go to the unfused side and install an inline fuse.
If you have test lamps it will make it easier.'
Should be able to find a spare spade terminal on the back of the fuse panel in the right spot
