173 Dizzy RIP
Electronic Ignition Dizzy 173
8 replies to this topic
#1 _RedKobra_
_RedKobra_
Posted 09 January 2018 - 08:06 PM
I have a UC with a 173. The centre of the old dizzy has dropped it's guts so I want to upgrade to an electronic one. I have a Bosch GT40R coil. What can I buy to keep the price low and reuse my coil?
#2 Ice
  • 15,122 posts
Posted 09 January 2018 - 08:25 PM
There is plenty of cheap chinese rubbish on the net but get a bosch one and you should be right
#3 _Bomber Watson_
Posted 09 January 2018 - 09:35 PM
THe electronic dizzy is not an upgrade.
Either rebuild the existing one or get another points dissy, if you absolutely must go electronic just get a stock unit, replace the module, get it rebuilt and get a coil to suit. Budget $300 all up.
Your money is far better spent fixing the existing one though.
#4 _RedKobra_
_RedKobra_
Posted 10 January 2018 - 11:22 AM
Bomber, what's the advantages of a points dizzy over an electronic unit?
#5 _RedKobra_
_RedKobra_
Posted 10 January 2018 - 02:45 PM
On closer inspection it seems the points have already been converted to an electronic unit, so I might as well stick with what I've got.
Rotor is a Bosch unit but obviously not original. Made to pass through the magnet and sensor.
#6 rodomo
  • 17,999 posts
Posted 10 January 2018 - 10:11 PM
They're aren't any
#7 _RedKobra_
_RedKobra_
Posted 11 January 2018 - 12:54 AM
Apparently Bosch no longer make the kits or the replacement rotors. However if I use a standard rotor I can install one of these stealth units pictured below. Made in the UK.
#8 Dr Terry
Dr Terry
  • 3,276 posts
Posted 11 January 2018 - 06:49 AM
Getting back to the original post, what did you mean by "The centre of the old dizzy has dropped it's guts" ? If it's the advance mechanism that you mean, your problem won't be fixed by fitting an electronic conversion.
Dr Terry
#9 _RedKobra_
_RedKobra_
Posted 13 January 2018 - 01:53 PM
Dr Terry
As I removed the distributor cap, the carbon conductor fell out. I have since replaced it, but the rotor also needed replacing which created further issues.
