Clean up of triples?
19 replies to this topic
#1 Pollarized
Pollarized
  • 27 posts
  • Name:Gary
  • Car:LJ XU1 Replica, VL Group A, VL SL Turbo
Posted 11 January 2018 - 10:26 AM
Hi all, when i bought my car the guy was good enough to include a set of 175 triple su's, rebuild kits and even a book on rebuilding them. Now that i have the car RWC and registered i am looking to get the 202 (spare motor) in and i want to run the triples. My question is what is the best way to clean them up before i do anything else? As you can see the carbs and manifold look pretty crappy. Research has me looking at everything from soda blasting to CLR to Coke (the drink kind :D ) I'm sure some of you guys have travelled this road before.
#2 Ice
  • 15,127 posts
Posted 11 January 2018 - 10:28 AM
Hdyroblast would be best
#3 caterham2
caterham2
  • 348 posts
  • Location:Mansfield North East Victoria not the other one in QLD
  • Car:Ford Focus RS AWD Gone over to the dark side .. Mercedes-Benz SLK350 Ford Cortina 2 door MK1 Twin Cam
Posted 11 January 2018 - 12:16 PM
Yep water blasting/ hydro blasting is the go. Did up some Webers a while back, they cam \e up fabulously.
#4 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 11 January 2018 - 06:21 PM
Did you re-colour the webbers after the hydrablasting ? For that original look.
& yep hydrablasting is the only way to go.
#5 Pollarized
Pollarized
  • 27 posts
  • Name:Gary
Posted 11 January 2018 - 06:35 PM
Thanks guys, hadn't heard of this. Will see if i have someone local that does it.
#6 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 11 January 2018 - 06:40 PM
How soon are you doing the triples mate ? Gary
#7 caterham2
caterham2
  • 348 posts
Posted 11 January 2018 - 07:30 PM
No didn't bother as going on to a race engine, extra weight and all that LOL
#8 Pollarized
Pollarized
  • 27 posts
  • Name:Gary
Posted 11 January 2018 - 08:16 PM
I will probably be doing them within a few weeks
#9 henry57
henry57
  • 37 posts
  • Name:Stephen
  • Car:LJ GTR XU1 and L34
Posted 05 April 2018 - 09:47 PM
By the way, fyi they are not SU’s but Strombergs. Common mistake, but XU1’s had Strombergs. Is that a genuine Holden manifold too?
#10 liswar2
liswar2
  • 1,484 posts
  • Name:Wazza
Posted 06 April 2018 - 01:07 PM
Looks to be a early 72 set of xu1 strombergs on factory manifold
#11 Pollarized
Pollarized
  • 27 posts
  • Name:Gary
Posted 07 April 2018 - 10:35 AM
 Thanks for the correction, very new to the Torana world and learning all the time. Unsure as to the manifold, is there a way to check where the carbs and manifold started life?
#12 Kockum
Kockum
  • 476 posts
Posted 07 April 2018 - 10:51 AM
This would be a good  starting point - remove the air cleaner assemblies and note any numbers stamped into the face of carbs where the backing plates mount.
Depending on the numbers present, you may get a few private messages through the forum asking if you want to sell them .
#13 Pollarized
Pollarized
  • 27 posts
  • Name:Gary
Posted 07 April 2018 - 11:01 AM
Double post
Edited by Pollarized, 07 April 2018 - 11:13 AM.
#14 Pollarized
Pollarized
  • 27 posts
  • Name:Gary
Posted 07 April 2018 - 11:11 AM
Thanks for that Kockum, had a look and two of them are stamped 949 TA and one is stamped 949 TB
#15 Kockum
Kockum
  • 476 posts
Posted 07 April 2018 - 12:13 PM
Ok - a matching set of early 72 LJ XU1  carbs on the genuine Holden manifold [ after market manifolds don't have the firing order on them].
Worth big bucks - I hate seeing people get ripped off .
Approx value in my opinion - $ 1,OOO , NO BULL.
#16 Kockum
Kockum
  • 476 posts
Posted 07 April 2018 - 12:19 PM
I should also point out that I have my late 73 matching set and therefore have no interest in possibly buying these.
#17 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 07 April 2018 - 06:42 PM
Middle & outer 2. & i don't think they're worth a fortune unrestored, there's quite a number of hours in restoring them completely to a concours or near concours finish. I'm not talking about your adveridge joes type job.
#18 Kockum
Kockum
  • 476 posts
Posted 07 April 2018 - 07:11 PM
Yep, a lot of dough to be spent on them to be ready to bolt on.
949 TB should be the vac line carb. NO1.
949 TA - carbs 2 and 3 .
#19 fx48_eh64
fx48_eh64
  • 199 posts
  • Name:MrFX
  • Car:Fx
Posted 07 April 2018 - 10:46 PM
I sold a set of these for 1000 bucks near on 10 Yr ago
#20 Pollarized
Pollarized
  • 27 posts
  • Name:Gary
Posted 08 April 2018 - 09:44 AM
Nobody will be getting "ripped off" as they aren't for sale. Was just curious, thanks for the help.
