Squaring up front of lh lx torana
7 replies to this topic
#1 Shtstr
Shtstr
    Formerly lcxu105
  • 1,809 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 13 January 2018 - 07:30 PM
Just wanted to know if anybody has had to check the front alignment of their car after it has been damaged and where they took the checkpoints from.
I know the rails have been replaced in my LX hatch at some stage and I want to make sure the front of the car is perfectly aligned.
I have used the corners from the base of the windscreen diagonally across the front of the car and it is Within 1 to 2 mm of measurement to the front nose cone at the same reference points. Also I have measured directly from the corner of the bottom of the front windscreen to the front radiator support panel directly straight in alignment and it also is within 1 or 2 mm.
From that I am guessing that the front of the car is perfectly Square to the firewall rearwards.
Also is there any particular spot on the firewall that is used to measure to the chassis mounting Point holes on the front rails to make sure they are the same from side to side for mounting the front cross member.
#2 purrlx
purrlx
  • 1,330 posts
  • Name:Danny
  • Car:LX hatch
Posted 13 January 2018 - 07:46 PM
I have seen a pic on here of chassis measurements, pick up points for suspension ext all measured diagonally. Was sedan and hatch pic.
#3 Shtstr
Shtstr
    Formerly lcxu105
  • 1,809 posts
  • Name:Mmmmmmm
Posted 13 January 2018 - 08:20 PM
Only concerned about body measurements as all of the suspension is changed.
Edited by Shtstr, 13 January 2018 - 08:24 PM.
#4 Shtstr
Shtstr
    Formerly lcxu105
  • 1,809 posts
  • Name:Mmmmmmm
Posted 13 January 2018 - 09:54 PM
Anyone know the link for the post with check points?????
#5 rodomo
  • 17,998 posts
Posted 13 January 2018 - 10:50 PM
#6 purrlx
purrlx
  • 1,330 posts
  • Name:Danny
  • Car:LX hatch
Posted 14 January 2018 - 07:59 AM
Thanks Rob that was the one I was thinking of
#7 Shtstr
Shtstr
    Formerly lcxu105
  • 1,809 posts
  • Name:Mmmmmmm
Posted 14 January 2018 - 11:16 AM
Sweet can admin pin this post for anyone that is looking for this information down the track please.
#8 _THE ZODIAC_
_THE ZODIAC_
Posted 22 July 2018 - 04:49 PM
Google a tremmel gauge
