Trimatic vacuum hose
3 replies to this topic
#1 dans73lj
dans73lj
  • 50 posts
  • Name:Dan
  • Car:73 lj 4 door
Posted 22 January 2018 - 05:51 PM
Hello,
Was after some info on the vac line from the modulator to the manifold.
I do not have the standard steel tube and short hose ends, so I am going to run new vacuum hose.
I am in need of the size of the hose. The modulator looks to me like 5mm I.d.
Any help would be appreciated greatly.
Thanks Dan
#2 Dr Terry
Dr Terry
  • 3,276 posts
Posted 23 January 2018 - 08:37 AM
I believe that the tube that they used was just 3/16" bundy tube, the same as brake line.
Go to a brake place & get a metre of it & bend it to suit. Use a short piece of rubber hose to connect to the fittings at each end.
Dr Terry
#3 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 23 January 2018 - 03:18 PM
I'm pretty sure that Terry is right on the 3/16" bundy tube, obviously make sure not to kink the vacuum hose around the corners ect. I've had brand new vacuum hose with a tiny hole in it where they put labels on, so i check for that too now, saves you the headache of finding the vacuum leak.
#4 dans73lj
dans73lj
  • 50 posts
  • Name:Dan
  • Car:73 lj 4 door
Posted 23 January 2018 - 05:14 PM
Thanks for the info guys, I will give it a go.
Cheers dan
