JL Engine Number
14 replies to this topic
#1 ridgeroll
ridgeroll
  • 23 posts
Posted 28 January 2018 - 12:16 PM
I have a JL engine with number JL372066.
Does anyone have any details about the car it came from?
#2 koalasprint
koalasprint
  • 296 posts
  • Name:Steve
  • Car:LX SS Hatch
Posted 29 January 2018 - 06:58 AM
Only that it's from an LJ GTR. 202 Block. (Not XU1)
https://www.uniqueca..._engine_numbers
#3 Dr Terry
Dr Terry
  • 3,283 posts
Posted 29 January 2018 - 07:24 AM
Not necessarily. The 3300 (JL) was optional for both S & SL models in 1973. it was a not exclusively GTR in that year.
The 372066 will give a time frame for the engine.
Dr Terry.
#4 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,294 posts
  • Car:ɐuɐɹoʇ
Posted 29 January 2018 - 09:36 AM
Hi
Mid July 1973. I doubt that this engine was fitted to a GTR.
Bazza
#5 jd lj
jd lj
  • 2,106 posts
  • Name:James D
  • Car:LJ SVO
Posted 29 January 2018 - 11:28 AM
I'd be leaning towards a late July or sometime in August. My JL 363--- is from my late July Adelaide built car.
It should be on the vin disc anyway.
#6 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,294 posts
  • Car:ɐuɐɹoʇ
Posted 29 January 2018 - 12:34 PM
Hi
Not all engine numbers appear on the VIN disc.  I found JL372067. It was fitted to an S Model 2 door in Bris on 20/7/73. The engine numbers can be quite random - they were not necessarily installed in the same order that they were received from the engine plant.
Bazza
#7 XU-1 RAT
XU-1 RAT
  • 224 posts
Posted 29 January 2018 - 12:53 PM
Whats the cast date of this JL372066
#8 jd lj
jd lj
  • 2,106 posts
  • Name:James D
  • Car:LJ SVO
Posted 29 January 2018 - 04:20 PM
Dare I ask, dual cast date or single?
#9 TOERUNNER
TOERUNNER
  • 624 posts
  • Name:RODNEY
  • Car:73 lj gtr 73 lj 2 dr S
Posted 29 January 2018 - 04:48 PM
Hi
Bazza
My Brisbane built  09-73 GTR came out with JL283290
Edited by TOERUNNER, 29 January 2018 - 04:48 PM.
#10 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,294 posts
  • Car:ɐuɐɹoʇ
Posted 29 January 2018 - 06:03 PM
Hi
There are 18 or 20 JL engine numbers around that 9/73 period commencing with JL2xxxxx. Typically this range of numbers was in use in early 1973. I wonder if they accidentally stamped up some with a  "2" instead of a "3"? It would be interesting to see what cast date they had.
Bazza
#11 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 29 January 2018 - 06:20 PM
M2 cheers
#12 jd lj
jd lj
  • 2,106 posts
  • Name:James D
  • Car:LJ SVO
Posted 29 January 2018 - 06:21 PM
Perhaps those engines were not accessible due to more recent blocks/engines being positioned in front of them and towards the second half of 73 as existing stock was being used up then these ones could be reached and also used up.
My JL 363 --- is cast 27f3 if that's of any relevance.
#13 Dr Terry
Dr Terry
  • 3,283 posts
Posted 30 January 2018 - 08:08 AM
27F3 = 27 June 1973.
As the others have said, engine numbers are quite random.
Look it the logistics. The engines come from the engine plant on pallets, already in mixed number order. The forklift loads the first pallet off the line onto the truck & the pallets are then mixed again. At the assembly plant they are stacked in a storage area, where the first units in become the last units out. Depending on their turnover, 2 consecutive engine numbers could appear in 2 cars built weeks or even months apart.
Dr Terry
#14 S pack
  • 15,576 posts
Posted 30 January 2018 - 08:36 AM
Dr Terry
Agree.
#15 frash da bucket
frash da bucket
  • 1,890 posts
Posted 01 February 2018 - 01:24 AM
My JL Block is JL-417---,September cast.
Regards John
