Dan's Hatch Rebuild
#26
Posted 28 April 2019 - 07:38 PM
#27
Posted 01 May 2019 - 09:26 AM
Have noticed when they get a tap on the rails they end up wih a depression in the roof above the B pillar,
It goes away mostly once the rail is put in is right place.
The seam across the firewall usually opens up a tad as well.
Possibly things to check
#28
Posted 01 May 2019 - 12:26 PM
Haven’t seen a depression on the roof but it isn’t stripped back yet. And yes the seam in. The fire wall you can see a crack in the mastic (black sealant stuff) which will be checked as work continues. The more I look the more I am finding.
#29
Posted 13 May 2019 - 10:59 AM
#30
Posted 13 May 2019 - 06:52 PM
#31
Posted 13 May 2019 - 07:11 PM
#32
Posted 14 May 2019 - 12:21 PM
The chassis drawing floating around is all you need to get it right.
A good start would have been the distance between the gearbox crossmember bolt holes.
Then everything else would fall into place fairly easily.
Spirit level, good long straight edge and a tape measure.
My old mate panel beater had a measuring tool that extended equally either side of centre somehow.
Should have paid more attention to it.
Made measurements off the centreline a breeze.
#33
Posted 14 May 2019 - 12:57 PM
All of the above but with the addition of an absolute must have, being a perfectly flat floor or some other flat, level datum to work from.
You will also need a plumb-bob (or if you want to get fancy, a laser plumb-bob like tilers use will save you a heap of setup time).
Then just put masking tape on your floor so you can mark the centres from the drawing (below) and measure across the floor.
#34
Posted 14 May 2019 - 01:42 PM
#35
Posted 14 May 2019 - 09:01 PM
Weld a bit, measure, measure the measure. Have a beer. Look at it. Measure the tape measure. Weld a bit. Have another beer (or two?). Spot weld another bit, measure, stand back and look at it while having a beer.
Do the next bit tomorrow and good luck!
#36
Posted 16 May 2019 - 12:09 PM
Measure, then measure again.
I reckon some clecos would be the best investment you could make to get it right.
Probably go for the bigger ones. The usual size is 1/8th, and I think the bigger ones are 3/16th.
Means that if you need to move things, you only have a small hole to fix up at the end.
They are cheap, and have immense holding power for what they are.
I would reckon perhaps 40 or 50 to help hold things together would make the job so much easier.
#37
Posted 22 May 2019 - 04:01 PM
#38
Posted 22 May 2019 - 09:20 PM
Trial fit everything as you go...……...time consuming but worth it in the end.
#39
Posted 24 May 2019 - 08:54 AM
Brings back memories of when I did my car, difference with mine was the tunnel/firewall were pushed back 6 inches from the crash. After we pulled that out, it was very much like your shell. I got a full donor front end with rails intact, stripped the firewall out, cleaned it up and placed it up to the body, and it was crazy close to being an exact match. Just did a couple of tac welds here and there after clamping and measuring, put guards and bonnet on, check gaps and alignment, weld a little bit here and there, more checking, adjusting so on. In the end all good. Just be patient, and double check.
#40 _Drag lc_
Posted 11 September 2019 - 11:07 AM
hi Dan,
i just spotted your location I'm also in gladstone.
#41
Posted 12 September 2019 - 07:50 PM
hi Dan,
Yes same area
#42
Posted 13 April 2020 - 07:46 PM
#43
Posted 13 April 2020 - 07:52 PM
#44
Posted 14 April 2020 - 03:37 PM
#45
Posted 14 April 2020 - 03:41 PM
#46
Posted 14 April 2020 - 05:26 PM
The only holes should be the 2 big ones for the heater. And then the 2 in the corners that lead to drain it out the side behind the fendersPics are a bit dark. In this next pic there is 2 holes in the back of the phlenum, should they be there or should I weld them up. Behind glovebox area. 3D1F3C67-8E39-4DB5-AC17-22F1C7F6C763.jpeg
Id weld them up
Sent from my SM-G965F using Tapatalk
Edited by Mitchyboy, 14 April 2020 - 05:27 PM.
#47
Posted 14 April 2020 - 05:50 PM
#48
Posted 10 May 2020 - 05:25 PM
#49
Posted 10 May 2020 - 05:29 PM
#50
Posted 11 May 2020 - 04:38 PM
