* * * * * 1 votes
LX L32
81 replies to this topic
#76 My390
My390
  • 101 posts
  • Name:Dale
  • Car:LX sedan
Posted 24 January 2022 - 05:12 PM
How did you go lining up the k frame? Much easier (in my opinion) doing it like this without motor and box.
Went in really well. Less than an hour. Top went straight in and one outrigger was perfect. The other needed to be pulled in slightly. Going to  have to be very careful when putting the engine in to keep it all nice
Is it an LX K frame? I thought it was only LH's that didn't get the cover over the steering shaft coupling.
I believe it is an LX?  But I am not an expert. I am looking for a cover to get it right. Any advice is appreciated
#77 toryman76
toryman76
  • 1,082 posts
Posted 24 January 2022 - 06:36 PM
Cover over the rag joint doesn't fit if you are planning to run extractors. Not sure about cast headers but yeah I learnt the hard way.
#78 toryman76
toryman76
  • 1,082 posts
Posted 24 January 2022 - 06:38 PM
Also I'm pretty sure my early LX doesn't have provisions for the cover. Maybe they were still using up stock of LH k frames in early LX cars?
#79 My390
My390
  • 101 posts
  • Name:Dale
  • Car:LX sedan
Posted 24 January 2022 - 07:37 PM
Thanks. Great tip. extractors for sure so I will leave the cover for now.
#80 Shiney005
  • 9,033 posts
  • Car:Toyota Mirai
Posted 25 January 2022 - 11:34 AM
Maybe it was the post RTS cars that got it. I only made mention of it as an early crossmember would have different castor and camber settings for wheel alignment than a later one.
#81 308 Sunbird
308 Sunbird
  • 966 posts
  • Name:Stuart
Posted 25 January 2022 - 11:42 AM
Yep can confirm my early (Feb 76) LX has no provision for the cover and had basically all late LH running gear, suspension and brakes.
#82 My390
My390
  • 101 posts
  • Name:Dale
  • Car:LX sedan
Posted 28 January 2022 - 03:16 PM
It is a late 77 model so I will keep an eye out for a cover. If I can get the extractors to fit with it???
Not sure if I did the torsion rods on the boot hinges wrong but they needed some force to get them in
