When does it end with cars. We can never be happy with them.No.2 Bit the bullet!!!!
Typical overkill with minitubs,coilovers,b/w 3.9 lsd & rear discs rolling on 18x8 granges with sticky s03 tyres...once got settings right it hooked up hard but diff joint screwed up diff width(too wide) & tyre rubbed same spot as yours when it squatted under power...could take 265/50 or maybe scrape 255/60 with stock wheel arcg
You'd get same result with narrowed diff,adjustable top arms & minor metalwork to inner wheelwells & it'd still look standard.
Idealy i would shorten then diff 10,15mm and i should be be able to fit them on the wheels i have now.
Im having a bit of a hard time understanding wheel offset with a 7inch rim. According to this the wheel will move inwards 12mm but how much will the tyre move.
Is rim width measures from the tyre sealing area or overall width? I think i might have 7inch rims now because i measured from the overall width. in.
Sent from my SM-G935F using Tapatalk
Edited by brendan_h, 09 February 2018 - 10:39 AM.
