Trimatic temp sender
6 replies to this topic
#1 D-Train
D-Train
  • 171 posts
  • Name:Dion
  • Car:LC SL
Posted 10 February 2018 - 02:10 PM
Gday guys.
I’m looking st fitting a tranny temp gauge. Is there a way of fitting one to the pan without welding? What is everyone doing. I also have a tranny cooler so can fit online with that but I’ve been searching online for hours and can’t find anything specific for the trimatic.
#2 Bigfella237
  • 4,373 posts
Posted 10 February 2018 - 02:50 PM
I'm not sure an in-line sensor would be the best thing, you would either be measuring the hotter oil coming straight out of the converter, or the cooler oil coming out of the cooler, probably more accurate to measure the temp of the fluid in the pan itself?
I'm sure you could get a weld-in bung for a couple of bucks, then just pull the pan off and take it to a local engineering mob to TIG the sucker in for you?
Just make sure to choose a location that doesn't foul the valve body!
#3 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 10 February 2018 - 03:21 PM
I have seen dipstick sensors before !
#4 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 11 February 2018 - 08:00 PM
Yeah ,what Andrew said is pretty easy and
cheap.
I have an remote trans oil filter and
Oil cooler that i'll b running that has temp sender on the filter mount.pic
Attached File  20180211_202957.jpg   146.38K   5 downloads
#5 LXCHEV
LXCHEV
  • 3,510 posts
  • Car:'76 LX - 383 Chev
Posted 14 February 2018 - 09:01 PM
Inline trans temp sender unit works fine for me - installed in the rubber hose leaving the trans (before the trans cooler) - so i know it's the hottest reading.
#6 _sbc57lx_
_sbc57lx_
Posted 15 February 2018 - 09:50 AM
What's to go with theses remote trans filters ?    I was thinking of using one for a SB Chev conversion in an LX  & where to locate one ?   OR don't ??
#7 D-Train
D-Train
  • 171 posts
  • Name:Dion
  • Car:LC SL
Posted 30 May 2018 - 08:02 PM
Cheers mad torana. I bought one similar to your inline filter with sensor. So you recommend putting before the cooler? Do you happen to know which line is the in and which is out?
