UC rear swaybar fitment to LX hatchback
9 replies to this topic
#1 dale
dale
  • 21 posts
  • Name:dale
  • Car:ss hatch
Posted 12 February 2018 - 08:05 PM
Looking to fit uc type rear swaybar on my hatch. I have a salisbury diff so the mounts are on the diff housing. My question is does anyone have the dimensions for the brackets that bolt on to the front pivot on the top trailing arms so as I can make a set. Or can these brackets be bought seperately from somewhere like Kmac.
Thank you for any advise.
#2 mandytory
mandytory
  • 70 posts
  • Name:peter
  • Car:lh sedan gpac, uc hatch
Posted 13 February 2018 - 07:26 AM
Bought a uc style rear bar for my Lh about 30 years ago from Lovell's, came with all brackets. Should be available still.
#3 Toranamat69
Toranamat69
    Forum R&D Officer
  • Validating
  • 1,799 posts
Posted 13 February 2018 - 08:20 AM
Would be very easy to make yourself. I can take a pic later if no one gets there first
#4 myss427
myss427
  • 1,391 posts
Posted 13 February 2018 - 09:44 AM
UC top mounts are half on the chasis rail and spring tower, not on the control arm mount like a standard LX. Think A9X.
#5 dale
dale
  • 21 posts
  • Name:dale
  • Car:ss hatch
Posted 13 February 2018 - 07:31 PM
Thanks TORANAMAT69 that would be great.  If you could give me some measurements as well that would be even better.
#6 Toranamat69
Toranamat69
    Forum R&D Officer
  • Validating
  • 1,799 posts
Posted 15 February 2018 - 05:51 PM
Gday Dale, I'm having trouble connecting my phone to PC for some reason sorry it took a couple of days.
Here is the whiteline rear bar mount - you can buy the threaded pins and bushes for the end from various places.  The only bracket you should have to make is the cut off section of square tube.
Then just a couple of bolts and large washers.
Matt
Attached File  20180213_191014a.jpg   86.34K   1 downloads
Attached File  20180213_190952a.jpg   110.74K   1 downloads
Edited by Toranamat69, 15 February 2018 - 05:53 PM.
#7 Toranamat69
Toranamat69
    Forum R&D Officer
  • Validating
  • 1,799 posts
Posted 15 February 2018 - 07:14 PM
The square tube is 2" x 40 long.
The bolts are 3/8 Unf x 3/4"long with large flat and nylocs.
The threaded link pin is 3/8" x 125 long overall.
Edited by Toranamat69, 15 February 2018 - 07:35 PM.
#8 dale
dale
  • 21 posts
  • Name:dale
  • Car:ss hatch
Posted 15 February 2018 - 07:22 PM
Thanks Matt much appreciated
Dale
#9 Toranamat69
Toranamat69
    Forum R&D Officer
  • Validating
  • 1,799 posts
Posted 15 February 2018 - 07:41 PM
I just went and tried to measure my uc but it has flat tires so a bit of mucking around for another time.
The brackets are different for the uc.
I went and lined up the whiteline and uc sway bars and the uc one is about 50 mm wider hence the different brackets.
#10 76lxhatch
  • 6,480 posts
Posted 16 February 2018 - 07:40 PM
I have a VB-VS Commodore bar with the ends straightened in the press, the links just go straight through a hole in the upper arm mount bracket
