just purchased a set of 330mm front brakes for an upgrade on v8 lx, has anyone done this before? do i need to go to 17"cwheels or will 15 s fit? any recomendations for rear discs and required master cylinder? thanks
sorry was from upc the brake kit
Posted 15 February 2018 - 03:13 PM
Posted 15 February 2018 - 06:12 PM
Good luck. I don't think many people have had much luck in getting a 330mm kit to fit. Even my 290mm UPC kit took some modification.
Posted 15 February 2018 - 06:54 PM
Posted 17 February 2018 - 07:25 AM
thanks guys, better try to fit the fronts before i purchase rears i suspect then
Posted 17 February 2018 - 09:08 AM
Posted 17 February 2018 - 12:04 PM
Been lots of posts on the subject.
Mostly not good ones.
And the supplier isnt very helpful about the issue either if they are from the same place.
Posted 17 February 2018 - 02:19 PM
Not having a dig, but seriously why do people not do a quick google search of a product before buying it?
Getting a $15 knife off ebay, fair enough, but a $1200 + brake kit, i'd spend a week reading shit before shelling that out, and in the case of the UPC 330 there is no way in hell I would be buying it after the first hour of looking into other peoples experiences.
Posted 17 February 2018 - 04:22 PM
the post about successfully fitting the 330mm kit is #34 on page 2 of the following link
http://www.gmh-toran...e-2#entry875156
Posted 17 February 2018 - 04:36 PM
THE post hahaahahhahaa.
Posted 17 February 2018 - 08:50 PM
The taller top balljoint is but an excellent improvement also if you go that way. I have the same Howe racing ones.
I got taller poly droop stop thinngy too rather than adding metal.
Matt
Posted 24 February 2018 - 03:27 PM
oh ok , might try to sell on the kit and go for a hoppers or willwood kit that will bolt straight on and pass no probs, and yeah i spoke to upc prior to purchase and they said would bolt striaght on , and purchased on ebay auction for 500 so obviosly got tricked intoit a bit, but thanks any way bomber
Posted 24 February 2018 - 07:19 PM
THat seems awfully cheap, did you buy it off someone who had tried to fit it and failed and was selling it on or is that the going rate?
Posted 09 March 2018 - 05:21 PM
no bomber got it off upc direct just lucky to get it dirt cheap off the auction over christmas
Posted 09 March 2018 - 10:24 PM
