Hey all,
So I have a predicament... I have an LH sedan body with rust in SIlls (both sides require new outers), RHR floor, boot wheel well and battery tray (and part of the rail under the tray) plus few other small pieces. I also have a full rust free UC sedan body.
Im after advice on whether i should cut up the UC to replace the parts on the LH OR walk the front off the LH (and other LH noticable pieces) and add it to the UC avoiding most of the rust repair plus ...gaining trans tunnel with hand brake, mounting points for bucket seats and the UC rear end. I will also be using the UC front end on the LH.
Of course I would want to utilise the LH tags, so im not sure if using the UC cab would prevent registration down the track.
I would appreciate some feedback, ideas or maybe info from someone who has been down this path.
