Twin throttlebody manifold for ls2 lx
11 replies to this topic
#1 _LXLS2_
_LXLS2_
Posted 08 March 2018 - 05:18 PM
Hi Guys, i have an lx, running an ls2 with a big custom twin holley manifold. I am wanting to go back to injection via a proflow twin throttlebody setup to try to get the motor under a a9x style scoop. Has anybody used the proflow setup on their ls powered torana? If so what are the dimensions ie height of the manifold, throttlebodys etc. Or does anyone have any ideas on another manifold setup which allows it to fit under an a9x scoop or smallish reverse cowl. It is a high hp engine(660fwhp)so i think the standard manifold will not cut the mustard. Hope the link works for the engine pic.
#2 _LXLS2_
_LXLS2_
Posted 08 March 2018 - 05:20 PM
Another pic
#3 DMLC71
DMLC71
  • 424 posts
  • Name:Daz M
  • Car:1971 LC 4 door
Posted 08 March 2018 - 07:19 PM
C.O.M.E racing in Victoria I rekon will have a solution
#4 Holdenbn74
Holdenbn74
  • 147 posts
  • Name:Brendan Nichol
  • Car:LH
Posted 09 March 2018 - 03:21 PM
Hi mate,
I have a Holley sniper efi setup and manifold is approx 9” height.
My setup is 130mm out of bonnet so ordering a 5” Torana scoop to cover but currently running a hole in the standard scoop.
#5 _LXLS2_
_LXLS2_
Posted 09 March 2018 - 04:08 PM
Hi holdenbn74, cheers for that info. Greatly appreciated. Looks like i will go down that path for sure. Your setup looks killa. Very nice. Quick question, what ecu are you running?
#6 Bigfella237
  • 4,371 posts
Posted 09 March 2018 - 04:37 PM
Eww... please try to avoid using photobucket for image hosting Ben, your photos above are now gone unless you pay their ransom.
#7 _LXLS2_
_LXLS2_
Posted 09 March 2018 - 06:06 PM
Hi bigfella, lesson learned. I'll research some better options instead of photobucket. Cheers for the heads up
#8 Holdenbn74
Holdenbn74
  • 147 posts
  • Car:LH
Posted 09 March 2018 - 07:15 PM
No worries LXLS2. I run standard LS1 ecu. Plenty tuneable by the local guru here in WA.
#9 Holdenbn74
Holdenbn74
  • 147 posts
  • Car:LH
Posted 09 March 2018 - 07:49 PM
Showsheight from bonnet mate. Could go lower with smaller filters and thinner throttle bodies.
I will probably cut another 10mm from filter so it’s 120mm high, filters have high flow top so still should flow ok πŸ‘
#10 _LXLS2_
_LXLS2_
Posted 09 March 2018 - 09:48 PM
Gday again, that is a perfect height. Not too high but still looks tough. Very nice car you have there. My carbs are way too high out the bonnet to cover with a scoop, will definitely look into the setup you have. Once again cheers for the input
Bit too high
#11 Holdenbn74
Holdenbn74
  • 147 posts
  • Car:LH
Posted 10 March 2018 - 11:31 AM
Looks good high though hey haha bloody rules πŸ˜ŽπŸ‘
#12 _LXLS2_
_LXLS2_
Posted 10 March 2018 - 03:56 PM
Just lucky i live semi rural atm. I can get it out, quick drive down the long straight roads, then back in the shed. I haven't had a run in with the po po yet but im sure they wont like it.
