Registration Question
11 replies to this topic
#1 Regrow
Regrow
  • 43 posts
  • Name:Rowan
Posted 14 March 2018 - 10:35 AM
Hello all.
My question is can you register a LX hatch if you have no id plates and no chassis number?
Looks like chassis number panel has been replaced at some stage.
Regards Regrow
#2 hanra
    Adam, I need your advice...
  • 8,749 posts
Posted 14 March 2018 - 10:48 AM
No chassis number might get you into strife.
#3 Redslur
Redslur
    Has been Torana owner
  • 3,092 posts
  • Name:Gerry
  • Car:VP 5.0L Berlina, VZ CV8 Monaro
Posted 14 March 2018 - 11:03 AM
Without a chassis number you will be referred to the local authority for an ID inspection at a guess.
Just make sure it doesn't have a police number issued somewhere else in the engine bay.
Edited by Redslur, 14 March 2018 - 11:04 AM.
#4 Bigfella237
    Certifiably Insane
  • 3,018 posts
Posted 14 March 2018 - 11:42 AM
As above, you'll end up being sent to the police who will of course want to inspect it and establish the car's history to make sure it's not stolen. I've done this before myself and depending on the copper it may be a quick look over the car, or it might be impounded for forensic examination, which could take months.
Usually you can register a car without a compliance plate if the car has been previously registered, however without a stamped chassis number I'm not sure how you could prove that? Even if you have number plates and rego papers, who's to say it's the same car?
Even if you receive a "police number" I reckon you will still have trouble registering it as it was obviously never registered before with that new number? Bureaucratically speaking that means nobody has ever certified it compliant with the ADRs.
You may end up having to get an engineer's report to certify the car, similar to a personally imported vehicle?
#5 Regrow
Regrow
  • 43 posts
  • Name:Rowan
Posted 15 March 2018 - 12:42 PM
Cheers guys.
Should add car is a shell at present and rusty. Was going to carry out a uc / lx conversion using this body for panels.
Was an after thought that to save some effort to rebuild it using the uc as doner instead.
#6 Regrow
Regrow
  • 43 posts
  • Name:Rowan
Posted 15 March 2018 - 12:46 PM
Cheers guys.
#7 Bigfella237
    Certifiably Insane
  • 3,018 posts
Posted 15 March 2018 - 12:57 PM
Good call I reckon, the most valuable part I can see there would be the lower dash fascia if it isn't broken.
#8 Regrow
Regrow
  • 43 posts
  • Name:Rowan
Posted 17 March 2018 - 04:43 PM
Actually the whole rear end is quite good with very little rust or dents..
#9 rexy
rexy
  • 2,440 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 17 March 2018 - 05:39 PM
Will likely always be worth more as a repaired LX than a converted UC assuming both are doable with what you have.
#10 Bigfella237
    Certifiably Insane
  • 3,018 posts
Posted 17 March 2018 - 05:44 PM
Yes that's true but is an LX with no tags and no chassis number worth more than a legit UC?
And is it worth gambling tens of thousands of dollars rebuilding something you may not be able to register when it's done?
#11 Bomber Watson
Bomber Watson
    Not nearly as smart as Lazarus
  • 20,583 posts
  • Name:DJ
  • Location:Rockhampton, the exact center of my own TINY universe. Also the home of the worlds longest location.
  • Car:Mixed fleet of Taxi's and hair dresser mobiles.
Posted 17 March 2018 - 10:11 PM
You could just pull the tags and chassis number off a uc and say that its a LX with no tags or chassis number, so im going to predict that no, a LX with no tags or chassis number will not be worth more than a legit UC.
Edited by Bomber Watson, 17 March 2018 - 10:12 PM.
#12 StephenSLR
StephenSLR
  • 6,513 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 19 March 2018 - 11:12 AM
Could that also fall within the category of a kit car and he has to engineer it to current ADR's?
s
