Hi all , Im in the process of getting the Gpack ready for the panel shop.. Is there a Tool or special way of removing the gutter trim with out doing too much damage.... thanks Grant
LH gutter trim
_grantgpack_
, Mar 19 2018 01:06 PM
4 replies to this topic
#1 _grantgpack_
Posted 19 March 2018 - 01:06 PM
Posted 19 March 2018 - 01:27 PM
There are different sub-forums that would be appropriate for a question like this one, Grant. Although an admin will probably move it for you.
You want to pry it off from the underside rather than the roof side, preferably with something that's reasonably sharp on the end - but not super sharp on the sides - and reasonably wide to spread the load. You can do it with a screwdriver, but wider (eg. a well shaped pry bar with slightly rounded corners) would be better!
Edited by Heath, 19 March 2018 - 01:28 PM.
Posted 19 March 2018 - 08:08 PM
I have read somewhere that a wide brick bolster works well and spreads the load like Heath said, Do from under side. I have not tried it though.
#4 _GMH-001_
Posted 20 March 2018 - 01:35 PM
As Replicar said a bolster is perfect. Its the only tool I use and have removed moulds from a variety of cars over the years
#5 _grantgpack_
Posted 21 March 2018 - 06:59 PM
thanks
