Front shocks details lj lc torana
3 replies to this topic
#1 _Werner1977_
_Werner1977_
Posted 23 March 2018 - 01:06 PM
Hey crew,
So I am an inexperienced car builder, getting my hands dirty as a hobby.
My Question is, hopefully easy to explain.
The fronts shocks mount with a long single bolt on the top, I get that, but the bottom has two unc bolts, is the shock on the inside or outside of the holding position?. And then, what part order does it need (Eg. Bolt, washer, shock, washer, nut)
I have attached a photo to ask if the shock goes on the inside as is, or outside of that frame holding position.
Anyone with advice, please help, or if there is a book you can recommend, I will invest to build my knowledge.
Edited by Werner1977, 23 March 2018 - 01:08 PM.
#2 John/lj
John/lj
  • 40 posts
  • Name:john
  • Car:Lj torana
Posted 23 March 2018 - 02:14 PM
shock mounted on the outside of the lower wishbone, nuts and bolts as you said
#3 _Werner1977_
_Werner1977_
Posted 23 March 2018 - 03:16 PM
John, you are a Legend, thx mate.
#4 rodomo
  • 17,999 posts
Posted 23 March 2018 - 08:35 PM
The nuts are welded in from the factory.
