Gear box
8 replies to this topic
#1 Chriso0327
Chriso0327
  • 68 posts
  • Name:Chris
  • Car:Torana
Posted 07 April 2018 - 04:59 PM
Trying to put the xu1 box into the motor but seems to be a bit long, wont seem to go right into the spigot bearing.What is the imput shaft length supposed to be mine is about 85mm
#2 meanmachine72
meanmachine72
  • 2,005 posts
  • Name:Jono
Posted 08 April 2018 - 11:16 AM
maybe wrong spigot..was it a manual before?
#3 Bigfella237
  • 4,371 posts
Posted 08 April 2018 - 12:06 PM
As above, if someone had a Celica box or similar bolted up before it may have the wrong spigot?
Is the clutch aligned properly?
Are you bolting the bellhousing to the motor first and then finding the gearbox won't snug up to the bellhousing? Or is the box and housing pre-assembled?
Have you dialed-in the bellhousing on the engine just to make sure everything is centred?
As far as I know there are only two different input shaft lengths for all Aussie 3 & 4 speed gearboxes, a longer length for V8's and a shorter length for 4 & 6 cylinder engines, but I don't know the measurements off-hand (it's a fairly noticeable difference).
Also check you have the correct front retainer (the 'nose' that the throwout bearing slides along), again there's two different lengths available depending on the engine and I'd imagine the V8 version would foul on a 6 cylinder clutch plate?
#4 Bigfella237
  • 4,371 posts
Posted 08 April 2018 - 12:15 PM
Just found this picture (V8 on Left, 6cyl on Right)...
#5 Chriso0327
Chriso0327
  • 68 posts
  • Name:Chris
  • Car:Torana
Posted 08 April 2018 - 02:01 PM
91B36917-51F9-4763-A198-A9E6867E03A7_zps
#6 Chriso0327
Chriso0327
  • 68 posts
  • Name:Chris
  • Car:Torana
Posted 08 April 2018 - 02:19 PM
URL=http://s95.photobuck...7ark.jpeg.html]439CF165-CF26-4BC4-AA4F-1AA18590512F_zps[/URL]
URL=http://s95.photobuck...rgrk.jpeg.html]2112187F-C469-4E61-BADA-CB293CE76CA8_zps[/URL]
#7 Chriso0327
Chriso0327
  • 68 posts
  • Name:Chris
  • Car:Torana
Posted 08 April 2018 - 02:22 PM
Nose is about 80-85mm in length
From front of box to tip of spigot is about 170mm in lenght
Does this sound and look right for a m20 xu1 gearbox to marry up to red 202 block?
#8 S pack
  • 15,538 posts
Posted 08 April 2018 - 02:33 PM
Yes, looking at your pics the input shaft is correct length for a 6cyl aussie 4spd.
Did you install a new clutch assy and did you use an alignment tool or an old input shaft to align the new clutch plate?
I've had occasion to be flat on my back under the car wrestling with the gearbox and swearing to god next time I'll get a mechanic to do this shit because the box won't slip in like it's supposed to.
The suddenly you hold your tongue the right way and box suddenly slides in like a bought one.  :)
#9 RallyRed
  • 7,840 posts
Posted 08 April 2018 - 06:14 PM
Hi,
As above I guess, ...... did a g/box swap on the LJ the other day. No reason, except to replace a good box with a 496 cluster, for a good box with a 899 cluster.
Pics below are of the one that was in the car , FYI
Edited by RallyRed, 08 April 2018 - 06:14 PM.
