Steering Columns
7 replies to this topic
#1 Regrow
Regrow
  • 43 posts
  • Name:Rowan
Posted 10 April 2018 - 09:46 PM
Hi All,
Could someone shed some light on the differences in steering columns LX/UC?
I'm aware of the Indicator stalk and housing but is there any others? ie shaft etc?
Also I have one with markings. See Pic. Any ideas on what they mean?
Regards
Regrow
#2 Bigfella237
  • 4,363 posts
Posted 10 April 2018 - 10:17 PM
I'd guess that first part may be a date code?
Something 2B8 maybe? Possibly February 1978?
#3 Dr Terry
Dr Terry
  • 3,267 posts
Posted 11 April 2018 - 07:56 AM
There are actually 3 styles of columns. There's the regular LX with the 2-eared silver ignition barrel & the hi-beam switch with the thin stalk & the then there's the UC style with HX/HZ stalk & the single-eared black ignition barrel. The much more rare version is the late LX, which has the LX stalk but the later UC ignition barrel.
AFAIK the shafts & most internals are interchangeable between all 3.
Dr Terry
#4 Statler
  • 6,281 posts
Posted 11 April 2018 - 09:02 AM
Auto & 3-on-the-tree.
#5 Dr Terry
Dr Terry
  • 3,267 posts
Posted 11 April 2018 - 09:31 AM
Yes, there's the 3 styles of each group in that regard, but I though he was asking about the steering components which don't change with the shifter type.
Dr Terry
#6 Regrow
Regrow
  • 43 posts
  • Name:Rowan
Posted 11 April 2018 - 01:36 PM
Cheers Guys.
Anyone have info on what the markings are?
Also just noticed that there different ends on the shafts see pic.
Regards
Regrow
#7 myss427
myss427
  • 1,636 posts
Posted 11 April 2018 - 03:22 PM
Dr Terry
Noticed the barrel on A9X's had the single ear, was not sure if they were standard or updated, clears that up.
#8 Dr Terry
Dr Terry
  • 3,267 posts
Posted 11 April 2018 - 03:41 PM
AFAIK all A9Xs should have the single-eared silver barrel from the factory which all ALX, BLX & CLX Toranas should have. It is the 1978 DLX Toranas which should have the 2-eared black type.
Also the right hand column shaft( in the above pic) looks bodgy. That flat where the lower shaft connects doesn't look to be machined. It looks like a back yarder has attacked it with a file.
Dr Terry
