Chopped out cam lobe
10 replies to this topic
#1 _threeblindmice_
_threeblindmice_
Posted 14 April 2018 - 02:26 PM
Adjusted my tappets last week , but they started to rattle again , on closer look number six inlet  is hardly moving , after pulling out the lifter the bottom was concave . I run Holden oil filters will that save any metal getting to the bearings ?
#2 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 14 April 2018 - 04:04 PM
Rebuilding a holden 6, particularly to stock is so cheap, why would anyone not bother ? Order a new cam & lifters, pull it down, thoroughly clean it, fit new rings & bearings & you're good for another 200,000. Try rebuilding a modern engine with tty bolts everywhere & you'll love how cheap the old red is. For the price of tty bolts you'd rebuild the red engine almost !
#3 _threeblindmice_
_threeblindmice_
Posted 14 April 2018 - 07:47 PM
A reco motor sounds good , but I'm trying to work a deal for a JP for it at the moment , and was thinking of slipping a cam into to keep it on the road until the next motor is ready .
#4 RallyRed
  • 7,840 posts
Posted 14 April 2018 - 08:59 PM
Hi...reckon thos was related to your tuning issue from a while back?
#5 rodomo
  • 17,998 posts
Posted 14 April 2018 - 10:09 PM
Throw a new lifter at it....................she'll be right til you get your new engine.
#6 warrenm
warrenm
  • 2,106 posts
  • Car:1972 LJ Torana
Posted 14 April 2018 - 10:19 PM
Put a new cam & lifters in, change the oil & filter & away you go. If the filter didn't stop the metal from being circulated the filter wasn't working.
#7 _threeblindmice_
_threeblindmice_
Posted 14 April 2018 - 11:47 PM
Yes Col , it hasn't been at it's best  for a long time , but they just keep on going . I nearly put another lifter in it today it would keep it going ,but when I saw the bottom of the lifter and how little lift it had  I thought it better to spend the time and replace the cam . thanks Warrenm at least with a new cam I won't have to limit it's use because I'm in it everyday .
#8 RallyRed
  • 7,840 posts
Posted 15 April 2018 - 06:36 AM
yep..a bit of wear
#9 TerrA LX
Posted 15 April 2018 - 10:14 AM
Try locate chilled iron base lifters as per holden used, some cheap and nasty replacements out there these days, infact I would rather a refaced old set over a new inferior product...
#10 _threeblindmice_
_threeblindmice_
Posted 15 April 2018 - 10:29 AM
All I run terry , it was the last thing on my mine after 40 years of red motors it's my first cam problem .
#11 toryman76
toryman76
  • 1,082 posts
Posted 17 April 2018 - 06:03 PM
If you don't have an old set of lifters lying around whats the next best in terms of new ones on the market today?
