Solid lifter cams and full synthetic oils
Posted 16 April 2018 - 08:12 PM
Anyone had any long term experience?
Posted 16 April 2018 - 09:27 PM
Have had conflicting advice from good sources regarding the use of a full synthetic oil in a Holden V8 with a solid lifter cam.
I'd contact tk383 Tony on that one rexy, but they seem to run it in the USA with the solid cams. He'd be "the" man to ask though !
Posted 17 April 2018 - 06:38 PM
Penrite sell good synthetic oils with high zinc- if you decide to run synthetic run the penrite 10 tenths imho.
Posted 17 April 2018 - 07:22 PM
Posted 23 April 2018 - 08:07 AM
Moly is quite good from what I have read but not as easy to find easily accessible oils with it... Zinc has been successfully protecting flat tappet cams for the last 40 years and is easily accessible... You can buy penrite oils for relatively cheap and they are always stocked at Repco, supercheap etc.. From memory, the advantage of moly additives is it can stick to moving parts better than zinc which helps start up.
Posted 23 April 2018 - 07:55 PM
Posted 23 April 2018 - 11:56 PM
You can also use diesel oils, as they are usually loaded with zinc, as the older & larger diesel engines have flat tappet cams.
Posted 24 April 2018 - 12:41 PM
The guy at Crow cams wouldn’t commit one way or another. Not sure if he was one of the experts or workers.
It’s not a monster cam (5626). Still got a container of the good mineral stuff to use up so might procrastinate till next time.
Posted 24 April 2018 - 05:21 PM
I spoke with both the Penrite and Nulon technical folk who were confident a full synthetic would be fine.
Honestly you will be fine with a good synthetic- just make sure its one suited to older cars and with suitable additives. I've run my flat tappet cam on synthetics for ages and all sweet so far.
Posted 25 April 2018 - 12:19 PM
It's the high zinc content is what AV8 peeps heavily debated over in getting cams lasting longer.
Penrite hpr30 was the go to brand but formula/zinc content been changed that now better brands out there..heard of dudes switched over to diesel oils.
My f280 355 engine probably 10 yrs old...afaik hpr30 most of it's life
