Having 2 x 2000cfm fans should help it with an oil cooler, factory air con condenser & large 3 core radiator, new 355 & 3500 stall or is it an overkill?
Derale fan setup
Posted 20 April 2018 - 12:14 AM
Posted 20 April 2018 - 12:42 AM
No such thing as overkill when it comes to cooling systems!
The engine will never run colder than the thermostat allows, but can easily run hotter if the radiator & fans aren't up to scratch.
What type of controller will you be running?
Posted 20 April 2018 - 08:16 AM
I have a controller with the little adjustable bit you can twist up or down to the temp you are wanting. Similar (maybe an older version) of what's in this photo
Posted 20 April 2018 - 12:11 PM
Looks neat and compact.
Posted 20 April 2018 - 12:37 PM
available from ebay, summit racing etc - I generally jump on the US ebay as items like this are much cheaper that way.
Here is another that has slots for air flow which I feel may not help when sitting in traffic?? anyone had experience with any setup like these before?
certainly looks better than AU fans, but is double the price.
Posted 20 April 2018 - 05:52 PM
Will you need to upgrade your alternator ..
Posted 21 April 2018 - 03:03 PM
Posted 22 April 2018 - 12:52 AM
