Happy new year guys.
Thanks for all the comments regarding the line locker.
Eventually I would like to set it up to disable rear brakes from working when I press the brake pedal.
And you guessed it, to do burnouts while still having front brakes working as per brake pedal application.
Lost a bit of build momentum over Christmas/new year.
Had two weeks off work and had planned to really crack in to the Torana, got stuff all done.
Firstly busy with family and Christmas and all that stuff
My senator broke down New Years Eve, another bloody fuel pump failed. Still haven’t got that back together, waiting for a new witting loom for the fuel tank.
What a prick of a job removing a fuel tank from a VE from the garage floor.
Got converter cover, wiper motor, brake booster and a few little brackets painted black.
So nearly got working brakes, just need to rebuild the front calipers and machine down the front brake rotors.
All the brake hard lines are run.
Convertor cover bolted on.
Nearly got the fuel pressure reg mounted, want to get some silicone heat sleeve to slide over the fuel hard line to protect it from the heat of the extractors.
Lower radiator hose kind of sorted.
It’s not perfect but at least I can install the oil filter properly, used a WB Holden V8 lower hose and cut a bit off each end. Not perfect but I can address that again once I get it running.
Also got the extractors bolted up to the heads,no gaskets I just did the copper silicon only, fingers crossed.
So while on topic of front brakes.
I have read on here that I will need to machine 6mm or 1/4nch off the diameter of the rotor.
Looking at my setup, it looks like I will need to machine a bit more than that off the disc or the caliper bolts aren’t going to go in the holes.
That’s all good I can machine a bit more off, however now the brake pads will touch on the rotor center hub where the bearing are.
I spose I can grind down the brake pads a bit.
