painting rotors - Yes or No
15 replies to this topic
#1 Cook
Cook
  • 1,504 posts
Posted 14 May 2018 - 02:29 PM
Hi, just wondering what the majority feel about painting new rotors before installing? And if yes should you avoid where pad contacts rotors?  Thanks in advance. Cheers Ron
#2 rexy
rexy
  • 3,588 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 14 May 2018 - 05:01 PM
Not sure how well it will last but if you want to make sure you use very high temp paint. This will probably limit your colour choice.
Don’t get paint on the friction surfaces.
#3 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 14 May 2018 - 05:22 PM
Yeah, as rexy said, mask up the friction area first & you're going to have to use wax and grease remover about 3 times to get rid of any protective coating, + a scratchy pad to get into the course areas, then use a proper hi temp brake paint, you can get cast paint type finishes, or semi gloss blacks. Fairly simple to do if you do the prep. Gary.
#4 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 14 May 2018 - 07:18 PM
Purchase brake and calipers paint, colour of your choice.....VHT
Clean using brake cleaner
I found it best to sit the rotor on a sheet of paper, hub up. A nice night to work at.....I.e. not on the ground.
Cut a disk out of cardboard slightly larger than rotor diameter.
Cut a hole in it to fit over the hub.
Sit over the rotor and weight down.
Paint hub, and then the external diameter.
For disk brake rotors, mask the wheel stud holes from inside to avoid paint on the inside brake shoe surface.
If you do get some over spray, some brake cleaner on a rag can be used.
I’ve done a few. I found that the red takes forever to dry, Black not so much.
Just make sure you have time on your hands.
Attached File  231BF10B-B96C-4405-B8F5-795DC8E315F7.jpeg   245.52K   3 downloads
Attached File  D703E794-0169-4F0C-AB7C-0F4541D258C0.jpeg   293.28K   2 downloads
#5 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 14 May 2018 - 07:23 PM
Night = height
Disk brake rotor = hanbrake rotor, like Commodore rear disk
#6 RallyRed
  • 7,841 posts
Posted 14 May 2018 - 07:36 PM
Those rotors above look good. Nice job.
Reckon you can paint em Ron....reminds me of an interesting day in very big Western Sydney tyre place, when I went to get some tires fitted. A price so good that I drove from Newcastle to get them. VR Commodore.
You can insert the appropriate accent to the following -
Them - You need to get a wheel alignment too mate.
Me- Im good thanks, the old tyres were worn evenly.
Them - no, if you dont get an alignment, the tires will be stuffed when you get home.
Me - what? in 140km?
Them - yep.
Me - no, its ok, I'll wing it thanks.
Wait 5 minutes
Them - hey mate , we need to paint your rotors.
Me- why?
Them - if we dont, they will warp
Me - seriously? gee whizz, how much?
Them - $99?
Me- what colour?
Them - we are the only place in Sydney with all the good colours
Them- you want?
Me - no thanks.
....and so on.
I noticed on the way out that the waiting room was full of mums with kids and old blokes etc.
I wonder how many they skinned.?
So yes..I have it on EXPERT authority that rotors can be done.
#7 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 14 May 2018 - 07:44 PM
You must have visited my Leb cousins. I heard the older one had been released back into the community!
#8 RallyRed
  • 7,841 posts
Posted 14 May 2018 - 08:22 PM
ha ha Rexy...too close for comfort...or your crystal ball is working at 100%!
#9 Cook
Cook
  • 1,504 posts
Posted 14 May 2018 - 09:11 PM
Thanks guys.  Appreciate the responses and advice.  Tony, I like the look of yours and that is what I am looking to do. Surprisingly there are a few youtube videos where they are painting the whole rotor, which is why I posed that question, and I thought it wasn't the right thing to do. Cheers Ron
#10 Ice
  • 15,123 posts
Posted 14 May 2018 - 09:13 PM
Cmon maaaate those painted rotors will look fully sik on your commo cuz ✌️
#11 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 14 May 2018 - 09:38 PM
Hence why this bloke said "cast grey" or "black" it ain't a p plater mobile !
#12 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 16 May 2018 - 09:43 PM
These must of come from the western sydney tire place
Col 😂😂😂
There must be only a very thin coating on them
just to prevent rusting once made.
Attached File  20160219_165820.jpg   634.35K   4 downloads
#13 RallyRed
  • 7,841 posts
Posted 17 May 2018 - 09:33 AM
yeah, those buggers wont warp!.....p.s. did I ask you about your wheel alignment Maz?..looks really bad,
I can tell just by looking at your rotors mate.
Probably best to put it on the aligner.
#14 _2ELCS_
_2ELCS_
Posted 17 May 2018 - 10:31 AM
They are out there Col....
#15 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
Posted 17 May 2018 - 02:00 PM
I know what i would of said to him..
Probably .show me your teeth haha..stoopid cnuts about
deserves a good slap..
#16 _Agent 34_
_Agent 34_
Posted 19 May 2018 - 07:44 PM
be careful of painting the interface between the hub and the disc as this will cause issues with runout - i would not paint or if at all - just a light coat and away from the mating surfaces that hold the disc- been there and made that mistake
g
