Torque Wrench - recommendations
10 replies to this topic
#1 _Agent 34_
_Agent 34_
Posted 14 May 2018 - 08:16 PM
Guys,
I have an old warren and brown deflecting beam type of torque wrench and was considering buying a new fandangled one with the beeping noise and other LED lights.
can anyone recommend some they have used or am i better off sticking with the old deflecting beam type
thanks G
#2 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 14 May 2018 - 08:18 PM
I’m interested to hear more about this as well.
Have the wind-in type and find it to be unreliable.
#3 _2ELCS_
_2ELCS_
Posted 14 May 2018 - 09:20 PM
No need to reinvent the wheel Grant....
#4 ozyozyozy
ozyozyozy
  • 944 posts
Posted 14 May 2018 - 09:22 PM
Depends how often you use it.
Those warren brown ones are good, if your just a hobbyist and only use it on occasion, then it will be fine, wouldnt bother updating in a hurry alot of older mechanics still use them, i have a small version which is great for some things.
The LED beeping ones(display style) are good if your a mechanic and using it regularly, some of these also do angles not just ftpds/nm's so very handy on modern engines, snap on make a really good one, yes it is very expensive, like i said if you use it lots it can be worth it.
#5 LJ RB30
LJ RB30
  • 974 posts
  • Name:Trevor
Posted 14 May 2018 - 09:37 PM
I’d be getting the Warren & Browns calibration checked & sticking with it if ok. They were always the ones I borrowed cose I couldn’t afford them 😞 Since it was something that I didn’t use very often when I did need one I ended up buying screw type😞 Always dubious about its consistency but always make sure to undo when not used. If I had a WB I’d check it before I’d look at others but haven’t looked for many years now at what’s available . What does your mechanic use?
#6 piquet
piquet
  • 856 posts
Posted 14 May 2018 - 09:43 PM
I'd stick with the W&B. Just get the calibration checked.
I have mine that was given to me as a present in the mid 1970's. Had thecalibration checked about 10 years ago and it was still pretty accurate.
So the old W&B would be my go to.
#7 _Agent 34_
_Agent 34_
Posted 15 May 2018 - 08:05 PM
Will try and track down a person to calibrate the one i have. The socket or keyway looks like it's had a heap of use as it's a bit burred. I googled the company and they are still around and their website still stocks the beam type.
Jagged this one on ebay for 25 bucks ;
thanks
funny the engine builder today still uses his WB
#8 _2ELCS_
_2ELCS_
Posted 15 May 2018 - 08:46 PM
That's got to tell you some thing ?
#9 Dodgey
Dodgey
  • 437 posts
  • Name:Steve
Grant
Still in service!
Just need to supplement it with one with lower settings e.g. 1 > 20 ft ibs.
Steve
#10 _Agent 34_
_Agent 34_
Posted 18 May 2018 - 08:35 PM
Steve.
looks like in good nic and still got the box !
ha - figured that when i turned up at his shop and he pulled out the wb  and this was after my post lol
#11 _1965mjr_
_1965mjr_
Posted 19 May 2018 - 07:08 AM
Grant, you can buy that square drive as a seperate part if required, most other parts as well. Hard to beat a Warren&Brown.
Mark.
