Fuel tank screws.
23 replies to this topic
#1 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 03 June 2018 - 07:37 PM
Hi these are fuel tank screws removed from a one owner 1969 LC Torana "S" I have seen the phillips type screw heads on others ,does anyone have an early LC with the slotted heads around the fuel tank?maybe they changed to the Phillips head later on ?
#2 S pack
  • 15,535 posts
Posted 03 June 2018 - 07:52 PM
Have you had them re zinc plated?
#3 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 03 June 2018 - 08:07 PM
Yes I have Dave.
#4 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 03 June 2018 - 08:49 PM
Anyone have this type on early LCs?
#5 S pack
  • 15,535 posts
Posted 03 June 2018 - 10:35 PM
Yes I have Dave.
Dime a dozen at the nut & bolt supplies.
#6 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 03 June 2018 - 10:53 PM
Yeah probably ,I had other stuff done as well ,so it wasn't just the screws,I just want to know what's correct for a 71 LC Torana.
#7 S pack
  • 15,535 posts
Posted 03 June 2018 - 11:13 PM
Phillips head.
#8 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 03 June 2018 - 11:41 PM
Agree.. the big block has phillips..
#9 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 04 June 2018 - 12:05 AM
Cheers fellas.
#10 S pack
  • 15,535 posts
Posted 04 June 2018 - 07:13 AM
Phillips Pan Head to be more accurate.
#11 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 04 June 2018 - 12:04 PM
Im thinking they must have changed them to the Phillips head which is correct for my car ,but those slotted type definitely came from a untouched LC 161 1969 "S"around the fuel tank.
#12 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
Posted 04 June 2018 - 01:26 PM
What makes you think the tank has been untouched Paul..
because its a one owner?
#13 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 04 June 2018 - 01:50 PM
Point taken,no guarantees it wasn't in a prang or something ,I just have a feeling very early LCs had this type.Like someone to check a early original LC .Not that it really matters just interested.
#14 S pack
  • 15,535 posts
Posted 04 June 2018 - 05:35 PM
I doubt they would have messed around with slot head screws on the assembly line. Phillips drive are faster to work with.
It was common for panel shops to replace the lost original screws with slot head self tappers.
#15 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 04 June 2018 - 06:02 PM
True.yeah I'm convinced now.Just goes to show you,even if the car looks 100% original and untouched ,things get changed over its lifetime and non original screws and bolts are used.Dam ,wasted my time getting those zinc plated didn't I ?
#16 RallyRed
  • 7,833 posts
Posted 05 June 2018 - 10:14 AM
prob. too late mate, but 12/70 Adelaide. Phillips head.
#17 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 05 June 2018 - 05:49 PM
No worries ,thanks Col,have chased up some Phillips head.
#18 sibhs
sibhs
  • 2,702 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 05 June 2018 - 06:46 PM
Hi Paul, those slotted screws look like your everyday hardware shop wood screw from the 70's.  Definitely don't look like a car part.
Marty
#19 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 05 June 2018 - 07:46 PM
Yep ,believe it or not they came out of a one owner car that I wrecked about 10 years ago ,looked like they were factory ,seems the tank was removed at some point in time and the panel beater just grabbed anything .
#20 rodomo
  • 17,997 posts
Posted 05 June 2018 - 10:43 PM
I might be wrong but if someone could post a pic of the original screws you might find they have other markings?(red)
#21 smeer
smeer
  • 1,526 posts
  • Car:1970 LC 4-door
Posted 06 June 2018 - 12:14 PM
Pozidriv?
My fuel tank screws were... rust.  :tease:
#22 meanmachine72
meanmachine72
  • 2,005 posts
  • Name:Jono
Posted 07 June 2018 - 10:45 AM
i used marine grade stainless steel phillips head, old screws were rusted and rounded..
#23 stealthxu1
stealthxu1
  • 344 posts
  • Name:Stealth
  • Car:lc 2 door project
Posted 16 June 2018 - 07:30 PM
they had phillips head screws.
#24 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 16 June 2018 - 11:32 PM
Thanks Stealth ,sourced some.
