![Photo](http://www.gravatar.com/avatar/eeca300536f628e29719ad2c6d53976f?s=100&d=https%3A%2F%2Fwww.gmh-torana.com.au%2Fforums%2Fpublic%2Fstyle_images%2Fblackstream%2Fprofile%2Fdefault_large.png)
tripple su
Posted 05 June 2018 - 07:24 PM
my problem there number 1b 2b 3b does 1b at the front or the back end of the manifold
Posted 05 June 2018 - 08:52 PM
fiting su to redline manifold
No idea what you mean by the 1b2b3b numbers??? Where the SU carbs sit is fairly irrelevant. The carbs do not have a specific port that they need to feed. Sometimes, if using a mix of left and right hand SUs, you need to think about placement of each carb on the manifold but in reality, if they are all the same type (if float bowls to the same side), which port the carbs feed is irrelevant.
Pictures might help as well.
