Lower Trailing arm holes functions
8 replies to this topic
#1 Cook
Cook
  • 1,504 posts
Posted 06 June 2018 - 06:18 PM
Me again.  Just wondering what the holes in the lower trailing arms are for?  I know 2 are for the sway bar mounts (won't be using them).  There is one larger one on each arm which I thought was for a fuel or brake line routing but can't remember. And then one arm has an extra hole and not sure what this is for.  There are also two small holes at the top which from memory are for mounting a brake line bracket.  Just want to double check before I refit them.  Thanks in advance.  Cheers Ron
#2 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 06 June 2018 - 07:22 PM
The fuel & brake lines are mounted firmly on the body, wouldn't end very well if you put them on a moving trailing arm. Sway bar is the only thing mounted on them by memory.
#3 Cook
Cook
  • 1,504 posts
Posted 06 June 2018 - 07:57 PM
Sorry, I should have said hose.  I'm pretty sure that a brake hose has a P clamp screwed to the top of one of the arms but could be mistaken.  I also thought a fuel hose went trough one of them but again could be mistaken.  Cheers Ron
#4 lx308
lx308
  • 2,838 posts
  • Name:Tony
  • Car:Nuffin. Goin touring.
Posted 06 June 2018 - 08:06 PM
Large hole would be hand brake cable
#5 hanra
  • 10,832 posts
Posted 06 June 2018 - 09:18 PM
https://1drv.ms/b/s!...x0D3XRhYcjUc-DG
https://1drv.ms/b/s!...jaKPipep3Sq0-te
#6 Bigfella237
  • 4,373 posts
Posted 07 June 2018 - 04:18 AM
In the LC/LJ yes, they had the jacketed cable that ran through the trailing arm, but the LH/LX handbrake cable had a different layout, they were a bare cable that ran around the lower trailing arm mount to a bracket on the outer side.
At least I assume Ron is asking about the later models??
#7 Cook
Cook
  • 1,504 posts
Posted 07 June 2018 - 07:02 AM
Yes Andrew. It's for the LX.  Trying to get the pic reduced so I can attach it.  I have this feeling the large hole is to run the brake hose through, that comes from the t piece on the diff to the bracket next to the upper trailing arm where the hard line starts.  I think it runs through there to keep it out of the way of the exhaust, but I may be completely wrong.  Cheers Ron
#8 Cook
Cook
  • 1,504 posts
Posted 07 June 2018 - 07:21 AM
See if this works
#9 Cook
Cook
  • 1,504 posts
Posted 07 June 2018 - 07:27 AM
Brad, Your service manual looks better than the one I have but I have looked through both, and the parts catalogue, but can't see any references to the holes.  Cheers Ron
