cutting front guards
11 replies to this topic
#1 _Shelly`s LX_
_Shelly`s LX_
Posted 07 June 2018 - 01:32 PM
Attached File  7 june 2018 155.jpg   117.53K   7 downloadsthats standing face on drivers side
Attached File  7 june 2018 160.jpg   124.56K   4 downloads should cut along dotted line ?
Attached File  7 june 2018 158.jpg   56.64K   6 downloads thats passenger side face on
wondering where to cut  the guard
and
the wall behind needs a trim to by looks of it
and photos or ideas would be great
regards michelle
#2 warrenm
warrenm
  • 2,107 posts
  • Car:1972 LJ Torana
Posted 08 June 2018 - 06:45 AM
http://www.gmh-toran...tart-to-finish/
#3 _2ELCS_
_2ELCS_
Posted 08 June 2018 - 08:05 AM
Photo F#$ket has struck....No pics....
#4 dattoman
  • 16,473 posts
Posted 08 June 2018 - 08:53 AM
Its allegedly back
But because we mined all the pics we could...and no longer linked to bucket...and they didn't come over (not all could be sourced)... they are dead
Dennis did threaten to do a new thread when he does the next car ... not sure when that will be
#5 RallyRed
  • 7,858 posts
Posted 08 June 2018 - 06:50 PM
you should be at home on the Playstation Wayne, making sure you have Turn 1 nailed!!
#6 _2ELCS_
_2ELCS_
Posted 09 June 2018 - 07:51 PM
Turn 1 is cool...had more trouble with 2 and 3 Col......Rainbows....
#7 _livo74_
_livo74_
Posted 11 June 2018 - 09:16 AM
just checking you saw andrew response in "rut's thread
Whenever I've done them I try to cut away as much material as the flare will cover, especially at the front lower corner where the flare meets the spoiler...
With the firewall, it depends how radical you want (or need) to go, most people just hammer the flange flat so the tyre may still hit but doesn't get cut.
I went searching back through Heath's thread for the 'proper' way to do it but a lot of his earlier photos are gone so not much help any more.  :sad:
#8 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 11 June 2018 - 06:23 PM
  I cut more out of the pillar floor area than in the above pic and wish I'd taken a little more.
#9 _Shelly`s LX_
_Shelly`s LX_
Posted 12 June 2018 - 05:17 AM
if i cut the guard as eveyone is  saying to how do i screw the flare to the inside of guard as the  part in the picture that is circled will be gone ?
#10 _livo74_
_livo74_
Posted 12 June 2018 - 09:59 AM
does your flare kit come with holes back there for ?reinforcement screws, or something?  mine didn't.
anyways, flare will be secure enough without
plus.. less room for dirt/gunk to catch and rot in/inbetween! which is gooood
#11 myss427
myss427
  • 1,636 posts
Posted 12 June 2018 - 10:07 AM
You should not need to take that much out unless your going for an 18 inch or bigger wheel, you need some of that inner edge to put self tappers through to hold the flare in place. I have 9.5 inch wide wheels on the front with a 5.5 back space and a 245 x 17 inch tyre. No touching issues. The fire wall mod is a must, and a decent flare that does not curve in at the base is needed.
#12 _livo74_
_livo74_
Posted 12 June 2018 - 10:18 AM
something i wish had known before mounting flares...
or
had waited till had bought tyres/tested wheel size.
anyways, whether it was just MY flare kit, or too large tyres, OR flare kit had warped??sucked in on itself after years of being unmounted..
i wish i had done this
and not saying push towards rear AND front.. enough to warp flare
..but just a cm either end. will be glad you did.
